Help with P0017 P0016.
Old Dec 19, 2020 | 10:36 AM
  #41
Cat Man HHR's Avatar
Originally Posted by Charleenatas
ok I will check and see if there is any oil coming out from the lower charge pipe. Does that mean my inner cooler has oil in it too?
Oil can collect in the intercooler "if" excessive oil is being pushed by the turbo.
Oil film will coat the cooler, but not to the point where if you remove a charge pipe oil drips out.
Old Dec 19, 2020 | 11:47 AM
  #42
I was pushing a lot, and I mean a lot, of oil through the charge piping when my LNF was at the end of it's life. I never got a TMAP related code.
Old Dec 20, 2020 | 12:35 PM
  #43
Charleenatas's Avatar
Update: The mechanic checked the lower charge pipe and cleaned out the MAP sensor and the code came off. Told me it was ok to take home. He tell me there's still no turbo power. Part of me thinks he dropped a nut or bolt in my turbo which caused that sound and pop in my turbo. So i drive it away. 2 mins later the car stops moving and shuts off in the middle of the street. It wont kick over now. He did put the timing chain wrong? Could the turbo not working make the engine stop running? Did he ruin my car and I need to sue him for damages? I need more experienced mechanics to work on this. I keep getting going back and there's another issue...
Old Dec 20, 2020 | 01:34 PM
  #44
What timing chain did he install, the crankshaft sprockets are specific to the 2.0 LNF , could he have installed the wrong balance shaft chain sprocket? Watch this video
Old Dec 21, 2020 | 06:39 AM
  #45
Update: The mechanic checked the lower charge pipe and cleaned out the MAP sensor and the code came off. Told me it was ok to take home. 1. But, was it oil fouled ?
Part of me thinks he dropped a nut or bolt in my turbo which caused that sound and pop in my turbo. Doubtful since he shouldn't have had the turbo "opened" up.
So i drive it away. 2 mins later the car stops moving and shuts off in the middle of the street. Should have called him to come tow it back to the shop
It wont kick over now. Won't turn over or turns over but doesn't start.
He did put the timing chain wrong? Hard to say.
Could the turbo not working make the engine stop running? Again. Hard to say but probably not since it was running.
Did he ruin my car and I need to sue him for damages? Don't know but you would need to prove it.
I need more experienced mechanics to work on this. I keep getting going back and there's another issue...Yes. Sounds like it
Old Dec 21, 2020 | 11:03 AM
  #46
From what I've been reading, this person who has no working knowledge of this car and needs answers from people who have.
It's a sorry change of events for her (?) that she depends on "fly by night" mechanics to "fix" her car.
Or maybe they do and other things are now a cause of problems.
A list of events/repairs would be helpful, instead of rereading this complete thread.
juicy
2.4L Performance Tech
39
Mar 2, 2022 02:31 PM
SweetTrixie74
Nov 28, 2018 12:15 PM
tlink211
Jul 9, 2018 06:11 PM
rlee63a4
93
Dec 11, 2017 05:22 PM
Danman03
May 12, 2016 04:08 PM
