Help with P0017 P0016.
Old Dec 14, 2020 | 09:02 PM
Maybe it’s an early built 2010 or very later 2009 SS what is in place of the gauge pod?
the P0016 and P0017 codes , well they don’t pertain to the VVT solenoids!
but both point to stretched timing chain
https://www.obd-codes.com/p0016
https://www.obd-codes.com/p0017
Old Dec 14, 2020 | 10:32 PM
Charleenatas's Avatar
It has a flip cover and has a spot to hold sunglasses. I will post some photos of the HHR. Just been waiting till it has more work done. I will ask the mechanic to replace the chain and the other parts after he's done trying the actuators.
Old Dec 14, 2020 | 10:57 PM
Steve. All 2010 SS's had the RPD. There were no early ones without it.
If there is no RPD then it wouldn't be able to show boost since the 2010's didn't have the pillar boost gauge.
Old Dec 14, 2020 | 11:09 PM
I wish I had the pillar gauge. I can't find a single gauge pod pillar anywhere. The only thing missing in this HHR is the boost gauge.
Old Dec 15, 2020 | 10:12 AM
If it really is a 2010, and an SS, then it is not missing the boost gauge, it is missing the Reconfigurable Performance Display.
Old Dec 15, 2020 | 10:28 AM
Year is easily found by looking at the 10th digit of the VIN. a 9 would be 2009 an A would be 2010.
Old Dec 15, 2020 | 01:17 PM
I mean it is missing a boost gauge. There is no boost gauge or that ugly display thing on the dash. It was removed by the previous owner. It would be nice to see the boost on the pillar. GM used to have a single pod pillar.
Old Dec 15, 2020 | 01:44 PM
The trim piece with the boost gauge was discontinued awhile back, sometimes they pop up on EBay, perhaps hellshotrod might have one for you. Send him a PM
Old Dec 15, 2020 | 01:55 PM
Thank you. I will message him.
Old Dec 15, 2020 | 02:39 PM
Cat Man HHR's Avatar
No offense but are you sure this is a real 2010 HHR SS ? Reason for asking is that you can't just remove the RPD unit. The car won't run without it plugged in and operating. Well, unless you do a bypass of the system but I haven't heard of anyone doing that on the HHR SS.
George here's a how to from the Cobalt forum.
https://www.cobaltss.net/forums/08-1...ur-rpd-206202/
