I'm gonna get cold air into this motor or else!
i love how this thread's title is "i'm gonna get cold air into this motor or else!"....... yet it's about getting cold air into a hot turbo, which then blows the now hot air into an intercooler mounted on the front of the vehicle and then into the engine. a cold air intake for the turbo is pointless. if you want the air to be any cooler going into the engine...... add water/meth injection or a co2/nitrous intercooler sprayer.
just saying.
just saying.
just saying.
just saying.
Aggreed also on Meth or Co2. Local speed shop recommended leaving stock IC and then adding the Co2, going to a bigger IC without a bigger turbo(yes, has a larger cooling volume) you actually lose power. Personally to me, Co2 is cheaper to fill on a continous basis, and I'm still leary about adding a mix interanlly. Under the right(wrong) conditions you run the risk of poping your intake. Open valve+misfire=ka-boom! Now if I F-UP the Co2 install, I can pop welds on the IC , or worst case, I could over-cool and compress too much and start to stress the head-bolts, and or cause blow-by on the rings. Either way it's a crap shoot.
just saying.
just saying.
Here's some Poindexter info that certainly applies to intercooler heat exchangers. Although I deal with this stuff on a non-automotive basis, this is probably why the HHR SS intrigues me so. Water or meth injection is actually an old technology with a new twist. It's commonly referred to as indirect evaporative cooling (IEC). Evaporative cooling is the simple evaporation of water or other evaporatives. Latent heat is drawn from the air (Latent heat is that of which is absorbed without causing a rise in temperature). Wet-bulb temperature, as compared to the air's dry-bulb temperature, is a measure of the potential for evaporative cooling. The greater the difference between the two temperatures, the greater the evaporative cooling effect. Evaporation rate depends on the humidity of the air and its temperature. With that said, if you have a cold pipe gauge, monitor it on misty days. It might surprise you as you may see a 10d F or more reduction in intake temp which means more condensing of air molecules resulting in more energy.
So in other words our cars run better in the fog.... actually makes sense, as water cools everything, its the alcahol being used to speed up the process I don't care for. It is an old tech, but much needed to keep/increase performance of aircraft especially as altitude increased(think propellers).
