NEWS FLASH....I lost my Turbo tonight....
Old Apr 13, 2009 | 11:11 AM
bad03xtreme's Avatar
Where else are connections that I should check. I checked the two coming from each side of the intercooler and the clamp behind the airbox. Are there any others that need to be checked?
Old Apr 13, 2009 | 11:58 AM
HHR Diablo's Avatar
I have an issue with mine as well... When they replaced the bottom sensor, they managed to crack the little barb fitting next to the sensor. There's a little hose that routes back up to another sensor. Everything was fine until that barb fitting managed to break completely off... Poof, no turbo. Stop and restart, seemed ok... Then I got the check-engine light... Then erratic turbo... Sometimes 10 to 15# boost then none...
Biggest problem is I took it back to the dealer and showed the service writer the hose flopping around, got a call that it was all fixed and the code cleared... Took it out and the same thing... Looked under the hood... Never fixed. Tech didn't even know this was the issue... New part in tomorrow... Stay tuned.........
Old Apr 13, 2009 | 02:47 PM
turbofreak's Avatar
I live close to you. If your dealer is Suburban on Jackson Ave, you need to
come to a better service dept. Try Crispin in Saline.
Sounds like your service writter was sloppy and did not tell service guy about
broken nipple and service guy missed it or never test drove the car- bad deal
in any case.
tf
Old Apr 13, 2009 | 03:26 PM
HHR Diablo's Avatar
Live in Ann Arbor and work in Milford... So I took it to Highland (Jay Chevrolet) which is 8 minutes away. I'll keep Saline in mind for the future though... Thanks.
Old May 9, 2009 | 09:09 PM
damronjr's Avatar
Mine just started making the grinding sound today, after just installing the spring yesterday and making about 10-12 passes at the drags last night. Only seems to happen when I left off and the BOV lets loose, but I know it has to be tight, I checked and double-checked it after the spring install.
843de
Apr 11, 2011 09:47 AM
Jersey Classic
Feb 21, 2009 03:22 PM
HipHotRod
South Pacific
29
Jun 30, 2008 01:04 AM
SIHHR
Mar 24, 2007 09:51 AM
SIHHR
Feb 8, 2007 09:02 PM
