Question on IC piping and BOV's
Old Mar 9, 2010 | 11:49 AM
asanti's Avatar
Thanks Woody.
Old Mar 10, 2010 | 08:35 PM
c2vette's Avatar
The stock system uses a recirculating valve that activates when the throttle closes suddenly to eliminate shock pulses and surging and also to keep the turbo spinning. The stock system also includes a blow off valve that dumps into the exhaust system. Regardless of any other mods, these are designed to work with the stock turbo and an add on BOV might cause problems, and even if not, would certainly not be of any benefit.
Old Mar 11, 2010 | 07:48 AM
mistermike's Avatar
This
Old Mar 11, 2010 | 12:35 PM
asanti's Avatar
Thank you very much gentlemen for all the responses!! I've the Hahn intercooler and piping in the garage waiting to be installed, so I'll forego the aftermarket BOV and just get the Dejon spring.
Later
Allex
Old Mar 12, 2010 | 07:40 PM
mistermike's Avatar
Forget the spring.
Old Mar 13, 2010 | 10:40 AM
asanti's Avatar
Originally Posted by mistermike
Forget the spring.
Care to elaborate? Forget it why? Is it a waste on a stock SS? What about an SS w/ the GM upgrade and future plans for a Trifecta Tune?????? Have you tried it yourself and found it does nothing?
Later
Allex
Old Mar 13, 2010 | 06:37 PM
mistermike's Avatar
If you're talking about a BOV spring, yes it's a waste. It's the same as changing BOV's, only less expensive. A BOV only needs to be upgraded when the turbo has been significantly enlarged, and it can no longer vent the volume of air it needs to on decel. Upping the blow off point with a spring can only increase the likelyhood of inducing compressor-damaging surge while offering no improvement in performance. If the stock spring is defective, and has become wea, and is blowing off before it's supposed to, that's one thing. But replacing something that's working as designed is a waste.
Old Mar 15, 2010 | 01:11 PM
asanti's Avatar
OK then. Thaks for that great explanation then mistermike.
Later
Allex
10RedSS
2.0L Performance Tech
34
Mar 8, 2013 05:56 PM
foolmoon_design
50
Mar 19, 2012 07:18 PM
mightymouse
25
Dec 18, 2008 01:22 PM
mightymouse
Jul 20, 2008 03:46 PM
