Seafoam ok ?
Old Nov 13, 2018 | 05:40 AM
Lethal Tendencies's Avatar
Seafoam ok ?
I have this habit of dumping a can of seafoam in my gas tank every couple of months with my vehicles. This is my first car with direct injection and was wondering if it was ok to do this. I read the owners manual and it reccomends using some GM injector cleaner. Which is probably not readily available.
Old Nov 13, 2018 | 07:46 AM
OK if it makes you feel good.
The 2008 manual suggests using TOP TIER fuel that has injector cleaner in it. Most brands are TOP TIER these days including Costco. I don't see anything about adding cleaners.
Old Nov 13, 2018 | 01:43 PM
X2 it’s up to you, I’ve not read anything about any benefits or otherwise.
Old Nov 13, 2018 | 08:31 PM
Well, with DI, it's not going to clean the valves. It's not going to clean the throttle body. Only thing it might help is the injectors.
Old Nov 13, 2018 | 08:40 PM
tiapetra's Avatar
A lot of people swear by Seafoam, but in reality it is about 60% pale oil.
If you are so inclined, probably an easier and more fruitful regimen would be to use a tankful of Chevron gasoline once in a while.
It contains probably one of the most popular injector cleaners Techron.
Old Nov 14, 2018 | 05:36 AM
No Chevron stations by me. But I can buy techron at the local parts stores
Old Nov 14, 2018 | 08:21 AM
TOP TIER certified fuels have all the injector cleaner you need.
Old Nov 14, 2018 | 08:34 AM
DrLoch's Avatar
Bingo. That is the problem with DI motors that everyone is trying to solve. PCV and leaky intake valve seals are a major issue all the manufacturers are fighting to stop the coking of the intake valve issue.
Here is one idea, https://noln.net/2018/04/01/dual-por...engine-design/
Old Nov 17, 2018 | 08:36 AM
Casa Del Gatos's Avatar
Texaco also sells Chevron gas with Techron in it. Only two stations I buy from and I have NEVER had a fuel-related issue with any car.
As to cleaners, I was a big fan of Seafoam too, but knowing it can't clean DI systems as well, I switched to a better value product: Berryman B-12 Chemtool
Berryman B-12 Chemtool.
Bought by the case, it is less than $4 a can. I add a can every 5 tanks or so to in the SS and a smaller amount to all of my gas-powered devices occasionally.
It absolutely keeps the injectors clean and on some vehicles, that is noticeable. Made a huge difference in my gas-powered golf cart.
badassbowtie
Maintenance and Upkeep
23
May 12, 2013 02:01 PM
whitelightnin
May 11, 2012 07:38 PM
rainmanva
7
Feb 20, 2012 09:33 AM
KissMy08SS
7
Jan 17, 2012 07:11 PM
catdaddy137
May 2, 2009 09:04 AM
