Got the dreaded P0016 code
Old Nov 14, 2016 | 03:22 PM
Muddie's Avatar
Originally Posted by donbrew
Take a photo with you.
Can't find that "bracket" anywhere but can find used balance shafts for a 2008 cobalt 2.2 with that piece attached to swap out. The cobalt 2.2 is the same engine ????
Old Nov 14, 2016 | 03:26 PM
For those yes
Old Nov 14, 2016 | 04:48 PM
Got any wrecking yards in your area ? I'm sure there's got to be a few Ecotec
"junker" engines that you could salvage that part from.
A nice offer of $20 will probably get one of the employees to pull the part for you.
Old Nov 23, 2016 | 01:51 PM
Muddie's Avatar
FYI that bracket is only available on a brand new balance shaft but the used set I ordered online worked great! Car is back together and running great!! Thanks for all the help.
Old Nov 25, 2016 | 10:02 AM
Well this sucks, I spent all day and last night changing the timing and balance shaft chains, a fresh oil and filter and this morning , I took off for a cup of coffee and the CEL came on , low and behold the P0016 code? I guess I'm off to the dealership for a relearn!
Well the dealership was nice about it, explained that a relearn is not necessarily the cure, he tried a relearn, the scan tech II tool came back with the intake cam and the crankshft are out of position.
Seeing as I just replaced the timing chain he suggested it's out a tooth.
Well I'm home now letting it cool off and I'll open the 2.2 back up and see what gives!
Old Nov 25, 2016 | 01:27 PM
That would be p0315 for a relearn.
Old Nov 25, 2016 | 05:01 PM
Ah, right , I've got to remember my memory is failing fast!
Well I torn it down again and the crank was off a tooth, the GM guy said it's common the chain drops abit while you wrestle the exhaust gear into position, well that's fixed, and for my next trick, I ordered a pair of 2016 Camaro SS horns , Sweetie will be bringing them back with her from her visit with her Aunt Karen.
Old Nov 25, 2016 | 05:14 PM
Glad you got it straightened out Steve.
Don't you just hate it though when you have one of those moments.
Happens to the best of us.
Old Nov 25, 2016 | 06:23 PM
It was a long day and hard to work up top and see the chain down below, maybe I should of kept the floor mirrors from my old show car days!
hurst2001
May 17, 2020 01:55 PM
Chris'sHHR
Jul 29, 2017 12:27 PM
cpcook
Jan 30, 2016 07:41 PM
alfolsee2000
May 16, 2013 07:58 PM
Jeff®
Oct 25, 2008 11:12 AM
