Hhr wont start....low ding sound
Old Dec 22, 2014 | 04:27 PM
  #41
Lucky's Avatar
Ok no power at the IP fuse.
I'm having you check the bcm3 fuse to confirm we have connection to the under hood fuse box. You can pull the fuse to test, just one of the the pins will have power. We are testing the B+ bar inside the under hood fuse box.
If your battery connections are good to the under hood fuse box and there is no power to the B+ bus bar inside the under hood fuse box then the problem must be inside the under hood fuse box.
Old Dec 23, 2014 | 10:44 AM
  #42
hhrrat's Avatar
With the test light hooked to the radiator bar stud ground, the BCM3, test light is not lighting up.
Old Dec 23, 2014 | 05:36 PM
  #43
Lucky's Avatar
Ok. The big battery cable that connects to the front of the under hood fuse box powers up the B+ bus bar inside the under hood fuse box.
If you have power there and no power at bcm3 than there is a problem inside the under hood fuse box. (Just be sure that the battery cable conection is good to the box ).
Without power to the B+ bar your car won't start.
The under hood fuse box also known as a power distribution center. ( P.D.C.) snaps together and can be taken apart.
Most people mess with it a little and end up replacing it because they were unable to repair the inside contact plates.
When you moved the fuse box replacing the trans mount the connections inside the box must has got moved and are no longer making contact like they should.
Old Dec 24, 2014 | 02:47 AM
  #44
hhrrat's Avatar
I decided to remove the fuse box. Undid the the 4 bolts together with the 4 plastic clips that hold the two halves together. Tomorrow I will attempt to separate the top half that contain the fuses. I believe the top half can be separated to expose the circuit underneath the fuses, right?
Old Dec 24, 2014 | 11:59 AM
  #45
Lucky's Avatar
Yes it can be separated.
There was a post on here where someone had dissembled the under hood fuse box but I have not found it yet.
I would take pictures during the dissemble to help you put it all back together.
Good luck.
Old Dec 24, 2014 | 12:07 PM
  #46
LawDog88's Avatar
^ Auto-Corrected?
Old Dec 24, 2014 | 01:17 PM
  #47
Lucky's Avatar
Got me again
it's a combination of auto correct,fat fingers, and not being awake yet.
I'm a 3rd shifter so afternoon is my wake up time.
Old Dec 24, 2014 | 01:42 PM
  #48
LawDog88's Avatar
Got me again
it's a combination of auto correct,fat fingers, and not bing awake yet.
Now you're bringing Chandler Bing into this? :P
Old Dec 24, 2014 | 08:47 PM
  #49
No the new hospital machine, the one that goes Bing!
whoweth
Jul 1, 2015 03:00 PM
kalifdave
Feb 9, 2015 08:21 AM
PaperChaseHHR
Nov 18, 2014 03:19 PM
cccjoh
May 16, 2014 10:00 PM
Shanes0406
Nov 8, 2012 12:37 PM
