Won't start
Old Oct 6, 2019 | 04:11 PM
  #71
Originally Posted by charliehines
I did another compression check today I still have 90 on all cyclinders
Same gauge or did you used a different one?
Old Oct 6, 2019 | 04:18 PM
  #72
I found that they are different part numbers 12578515 and 12621505. It is unclear if they came attached to the new head or not, I've read both.
The non-VVT uses the same part. Maybe whoever put the sprockets on didn't pay attention.
I amend that:
the 2.2 VVT uses 12621505 on both
the 2.4 uses the different ones
and the intake cams are different
exh cams are the same
According to Mitchell OnDemand Estimator
Old Oct 6, 2019 | 04:23 PM
  #73
charliehines's Avatar
2011 hhr
I used a new gauge still got 90 psi on all 4 guess I'll pick up a gauge set and do a leak down next
Old Oct 6, 2019 | 04:32 PM
  #74
I amend that:
I know it seems I'm getting nowhere but hey I'll keep going if this doesn't I have a 383 stroker I'll drop in it lmao... no again thanks guys
the sprockets are both 12621505 I took them and the pahsers off the old head. I really do want to thank everyone for the help
Old Oct 6, 2019 | 04:38 PM
  #75
I'm afraid I'm of no further use. The only thing is that tensioner the engine is supposed to have the hydraulic version; I don't know if the mechanical version works or not.
Old Oct 6, 2019 | 05:42 PM
  #76
Here's our how-to https://www.chevyhhr.net/forums/how-...-engine-56053/
I got the Harbor Freight one, there's information in the how-to for how I had to modify it so it would work.
Old Oct 6, 2019 | 05:43 PM
  #77
Please post a picture of the sprockets, they should both have a triangle and a diamond, I can’t see the full circumference of either sprocket.
Old Oct 6, 2019 | 05:58 PM
  #78
I amend that:
Just to clarify,
2.2 VVT engine uses 505 on both camshafts
2.4 uses 505 on exhaust, and 515 on intake.
I wonder if the shop put a 2.4 intake camshaft in by mistake? Not the phaser, Charlie said those were his used ones. Or maybe they shipped a 2.4 head?
Old Oct 6, 2019 | 06:42 PM
  #79
Hmm , a 2.4 head would come with 2.4 cam shafts which would require the two different sprockets.
could you post the invoice for your new cylinder head?
Old Oct 7, 2019 | 07:35 AM
  #80
Well I Thank you for all your Input Don. everything I replaced was the exact same parts that came factory including the tensioner.
