zzp 2.2 turbo clearance problems?
Old Aug 16, 2018 | 05:42 PM
racer213's Avatar
looking down you can see the alternator, radiator overflow and sheet metal. Very little room.
Looking for someone with a 2.2 zzp turbo kit ….need some help. I have most of it installed but the tube on the passenger side from the intercooler to the throttle body has no place to go. Anybody else with this problem and if so what did you do?
All zzp will say is "you need some custom fabrication". Cutting sheet metal is something you can't back out of...
any ideas?
danny
Old Aug 16, 2018 | 09:00 PM
I don't know about the ZZP kit..On an SS the throttle body is on the bottom of the manifold, so the pipe is routed through a different spot.
Old Aug 18, 2018 | 11:15 AM
racer213's Avatar
2.2 is on top so intake has to route from intercooler on r/h side and somehow by the radiator, coolant overflow res, not touch the belt, etc etc. I don't have it figured out yet but thanks
danny
Old Aug 18, 2018 | 12:11 PM
Cat Man HHR's Avatar
There is a possibility to use an oval piece of tubing in the tight space. Yes it does look like you will have to fabricate that pipe.
MOTRV8D
Feb 23, 2008 06:55 PM
lilbloohhr
Dec 23, 2006 11:40 AM
fishbreath
Mar 29, 2006 05:14 PM
