Electrically dead
Old Apr 12, 2020 | 01:57 PM
  #51
Cat Man HHR's Avatar
Don
Very good video you found.
Panel try what was shown and get back.
Old Apr 14, 2020 | 04:50 PM
  #52
Panelvanman's Avatar
After much digging, I found some broken wires in the drivers side kick panel. I soldered and heat shrunk them. Now I appear to have no troubles. It looks like they got nicked when a previous owner added some wiring running to the back and then removed them before I bought the car.
Old Apr 14, 2020 | 06:04 PM
  #53
So, it’s running ok, now? Great news!!
Old Apr 14, 2020 | 06:07 PM
  #54
Isolated's Avatar
Thanks panelvanman. Local shop spent $3000 looking for a similar problem on an HHR and found it above the driver's window. Don't know if that makes you feel good or bad but I'm glad your car runs
DId you use one of those open circuit finders that I see advertised?
Old Apr 19, 2020 | 04:00 AM
  #55
No, I actually couldn’t find the problem and started just looking for out of place things. Stuff that didn’t match my parts car. I saw a yellow zip tie on the harness under the dash and followed that bunch of wires down into the kick panel. Something had been added to the harness running down that side and when it was removed the harness had gotten a little cut. It just so happened to shake the rest of the way apart. I don’t even know if the broken wire I found previously contributed to this problem.
Topshape46
Feb 4, 2020 08:35 AM
stray_cat
Jan 10, 2018 03:30 PM
ruckdog60
Nov 16, 2014 05:25 AM
tntwolt
Jan 12, 2014 08:26 AM
Tulpa
Jun 21, 2013 09:37 PM
