Harmonic Balancer bad = New engine?
Harmonic balancer failure by itself is fully recoverable, with a replacement and maybe a belt. If you got some crank walk or something as the real root cause, then your guy is probably right. Doing major repairs on the bottom end might not make sense. You're doing the right things to ask some more questions.
This seems like a terrible idea. Why would you suggest this? How would you get it apart if engine work was needed?
Obviously it would not be able to be removed, but throwing away a 56,000 mile motor and spending $1000's of dollars when a few hundred dollar weld job might save it and then he could drive it until the timing chain needs replacement. It's just an option that the OP might not have thought of.
Arbius79
Maintenance and Upkeep
21
Aug 24, 2022 05:51 PM
