ATOTO android radio installation question
Old Feb 6, 2019 | 01:20 PM
Laplante's Avatar
is this what a nead that will provide me the 12 volt Accessory / Ignition too ?
Laplante's Avatar
Amazon Amazon
Old Feb 6, 2019 | 01:29 PM
Old Feb 6, 2019 | 03:32 PM
I tried to explain that there is no switched wire in the OE harness because that part is handled digitally by the computer.If you don't use the interface you will not be able to use steering wheel controls or have "door open" chimes.
If you need to find a source for switched 12V look on the BCM (the inside fuse box, below the radio) There are 3 fuse locations marked "spare" they are unused switched circuits, 2 20A 1 10A. If you don't understand tapping into a fuse box maybe you should find someone who does.
If you go to the crutchfield.com site you will find a wealth of information regarding installation. Your particular model does not really matter in regard to what wire is what.
I was not offended, just didn't know why you would be shouting after you had acknowledged the answer. That only gets you negative attention.
Old Feb 10, 2019 | 02:43 PM
Laplante's Avatar
thx very mush for your time !
Old Feb 10, 2019 | 06:24 PM
Is that the Canadian in you, or simply a typo, mush .
But seriously how is the install going
DoomBuggy
Fuel Economy - Hypermiling
Apr 19, 2012 05:00 AM
SargeRN
Oct 5, 2011 08:21 AM
Tominator
Aug 13, 2011 06:44 PM
bobiroc
Jun 19, 2011 07:42 PM
fatphil
Jan 5, 2011 04:23 PM
