fixed the speakers
Old Mar 9, 2021 | 03:49 PM
davitlee@aol.com's Avatar
fixed the speakers
Found this forum when my buddy's 2006 HHR had only tweeter noise. I thought, there must be a wiring or fuse issue if ALL the speakers except the tweeters are blown, right? Wrong. Took the front doors apart and pieces of speaker cone are falling on the ground. They are TRASHED. I fixed them up with 2 pioneer 6-1/2" universals and blade wire terminals. The stock are custom fit speakers in a custom GM molding but with a hack saw I was able to convert the OE speakers into adapters. I used some foam double-sided tape between the new speaker and the hole I made after removing the spokes, drilled holes to screw it on. Sounded great for a base model when done. The rear speakers are next.
Old Mar 9, 2021 | 04:42 PM
Did you know that using your email address as a screen name is "publishing" it to the world; anyone can now use it for whatever purpose they wish. Like spamming the world in your name.
Old Mar 9, 2021 | 07:38 PM
Great news! There’s many threads about the same method you used, thank you for the update for new members.
is there still an AOL.com? Let me know if you want me to fix that
LVJJJ
Oct 12, 2016 08:52 AM
ChadM523
Apr 18, 2015 06:09 PM
agmc4me
Apr 18, 2015 04:11 PM
abbs4601
Jun 16, 2014 09:58 AM
LawDog88
Dec 29, 2013 03:01 PM
