o2 audio speaker fitment questions
Old Dec 14, 2009 | 08:00 PM
wihockey11's Avatar
i was wondering if there is enough room in the back doors to extend the 6 3/4 speaker hole to 8 inch to fit these speakers http://www.audiosavings.com/products...a3b8209.r.aspx
abd is there a spot i can cut into to add the 4 inch speaker for these 3 way component speakers with out interfering with the power windows or anything or could i just mount it through the plastic door panel? http://www.audiosavings.com/products...39.r3a8bd.aspx
thank you very much
Old Dec 14, 2009 | 08:38 PM
wihockey11's Avatar
i dont wanna sound push but i need to knowif these speakers are possible bc i hafta order them soon as they will be my christmas present from my parents thank you how ever may know the answer happy holidays
Old Dec 15, 2009 | 06:22 PM
IgottaWoody's Avatar
putting that big of a speaker in the rear doors will move the sound stage to the rear...wont sound right..probbly over power the fronts unless its all amped and rear bias limited in which case would defeat the purpose....as for fit...yes can be done...just space the speaker away from the door, in other words mount the speaker on the outside of the dor panel with a spacer, that way there is no restrictions in opening size.
there i a fair amount of space between the door and door panel for mounting seperates....therefore no interference with windows...
Old Dec 15, 2009 | 09:48 PM
wihockey11's Avatar
ok thanks i just decided to go with the 3 way components up frnt and infinity kapa 2 ways 6 3/4 oversized 6 1/2 inch speakers for the rear ordered it all tn but thanks for the answer as for the 4 inch speaker that comes with the 3 way component i will just mount that through the plastic door panel all will be amplified bc a kicker 350.4 amplifier
jdobbins
May 6, 2015 05:29 PM
Wever
Feb 7, 2012 09:09 PM
American & Proud
Sep 4, 2010 01:37 AM
Chris-HHR
Aug 10, 2008 09:59 PM
BluetoothManiac
Jul 2, 2007 10:05 PM
