onstar control module where and how
Old Mar 29, 2017 | 08:42 AM
  #41
Not the blue one!!! Riggs!!!
Old Mar 29, 2017 | 08:49 AM
  #42
Go to your local GM Service Department and have them disable OnStar, then remove the unit. If you just remove the unit you will probably not be able to use the car.
Then ask all of your friends save their used tin foil so you can wrap your entire body. Who knows where "they" might have hidden the transmitter.
Old Mar 29, 2017 | 09:48 AM
  #43
I'd just open the hood, and start snipping all visible wires. One might actually get the right wire. :)
Old Apr 1, 2017 | 12:34 AM
  #44
Call Roto-Rooter®, that's the name, and we'll blow your troubles down the drain!
Old Oct 27, 2018 | 12:29 PM
  #45
CLeggett's Avatar
Location of OnStar module
Originally Posted by stealthman
Thank you so muych for the information.
This is very helpful!
Location of
Do you have to take out the back seat to take off the rear right lower panel?
Old Oct 27, 2018 | 02:01 PM
  #46
Originally Posted by CLeggett
Location of
No, fold down.
Old Oct 27, 2018 | 02:10 PM
  #47
CLeggett's Avatar
Just to be sure I'm doing this right, we are talking about the passenger rear lower quarter panel, right? I removed all of the right passenger rear lower quarter panel, and the panel will still not come off. I would have to remove the panel all the way up to the passenger rear door it looks like.
Old Oct 27, 2018 | 05:01 PM
  #48
Yes, you need to get the panel out of the car. I think you need to get the upper qtr panel off first. I am not sure what part you are having a problem with.
Arrows point to front of car
OnStar CIM
Battery if equipped
Same both sides
Old Oct 27, 2018 | 05:03 PM
  #49
How to gut your HHR
https://www.chevyhhr.net/forums/how-...install-13261/
Yes that’s all the rear interior quarter panel plastic panel
Old Oct 28, 2018 | 08:02 AM
  #50
CLeggett's Avatar
Thanks for all of the help, I'm going to try again today, y'all are the best!!
