Stereo speakers
Old Aug 31, 2018 | 01:10 PM
Doc brown's Avatar
Yes the factory setup is odd. That made looking at speakers more confusing than helpful.
I simply popped in the new Rockford Fostgate coaxials and left the factory tweeters alone. As aradmahogany said above I do have to pump the volume up just a hair but I have dramatically better sound quality. I really only drive the car back and forth to work now days so having higher end speakers wasn't worth it for me. Also the OP asked about "inexpensive yet good sound". Of course that's relative but there are plenty of aftermarket options available that won't break the bank and will still be better than the factory speakers.
Originally Posted by solman98
Use the original brackets and plugs on the new set. Just as easy.
Unfortunately the factory plugs don't fit all aftermarket speakers. I had to cut my wires and wire in the supplied connectors. But most speakers will fit in the factory mounts.
Old Aug 31, 2018 | 01:27 PM
solman98's Avatar
2 seconds with a hot soldering iron had the factory connectors on the new speakers.
Old Aug 31, 2018 | 02:01 PM
gio89kid's Avatar
Hey, just out of curiosity, since I just changed all of my speakers. I measured the factory speakers and they are indeed all 4 ohm, with the tweeters being 2 ohm.
Meaning the rear doors are a 4 ohm load to the amp and the front doors are a 1.4 ohm load to the amp. I didn’t measure the sub yet, but I do know it is a dual voice coil.
P.S. That is for the premium system.
Old Aug 31, 2018 | 03:13 PM
Doc brown's Avatar
Talking
Well, that's just cheating!
Old Aug 31, 2018 | 05:32 PM
tiapetra's Avatar
I also replaced all with Fostgate coaxials and left the factory tweeters. Sounds a lot better.
I got connection adapters for the speakers from Crutchfield for free.
MyfirstHHR
Oct 29, 2021 07:13 PM
captneuman
Dec 23, 2017 10:33 PM
Zachles
Apr 11, 2016 03:16 PM
PhatBob
Jun 22, 2010 08:34 AM
Chevy_dork04
Nov 7, 2008 02:16 AM
