2010 LT 2.2 Suspension+ Replacement: Strut/Shock/Link/Speed Sensor Hub/Rotor
Old Aug 30, 2022 | 06:57 AM
  #41
Vinnybagodoughnuts's Avatar
Originally Posted by planetrj
That's interesting! Due to all of the previous clunking cars on this forum when I first heard it, that was the first thing I changed, but with no difference. So, the next step is to change the Moog Links to the Delphi Links. But, since I'm changing that, I'm curious which Sway Bar Bushings you put on, because I put on Moog K201303, but I see there is also AC Delco Professional 45G10046. I might have those changed out back out while I'm at it.
I used the genuine GM bushings.
The really strange thing was the end links were clearly broken and the lca bushings were completely split.So when the clunk didn't go away I was kind of surprised.I also figured out a way to remove the sway bar bushings without dropping the cradle or removing the rear bolt/nut from the drivers side.I simply loosened the nut until it hit the underside of the car.Lifted the bracket as high as I could.Made one relief cut in the old bushing with a sawzall, screwed a 4 inch deck screw into the meat of the bushing and then I was able to grab the old bushing by the screw with a pair of channel locks..Sliding the new one back in was a lot easier then removing the old one.
Old Aug 30, 2022 | 07:47 AM
  #42
Good tip!
Old Oct 13, 2022 | 03:35 PM
  #43
RetroHHR2020's Avatar
i went and bought sway bar bushings - hope i got the right ones based on the above comments. I wanted to mention that after i changed my struts (rock auto) and stabilizer links (got some generic cheap brand off amz) the clunk went away... for a while, then i started hearing new, different clunks - i had noticed that ball joint bushings were also pretty gone so i was assuming i would have to just go ahead and rebuilt the whole front end.... then i decided to check the nuts on the links... i had found two sources for torque setting - one said 15lbs, another 20lbs... i didn't have my torque wrench handy that goes that low so i did it by 'feel'... turns out the CLUNK had returned because the upper nut on one side had loosened up. So i hand tightened it down harder... a few days later, the other side was loose - only the upper nut again. This time i prob put 30-40lbs and it's been quiet since.
QUESTION, does anyone have the proper specs for the torque set on the stabulizer nuts?
Old Oct 13, 2022 | 03:40 PM
  #44
59 Ft/lbs
https://www.chevyhhr.net/forums/how-...e-items-54648/
Old Oct 13, 2022 | 04:22 PM
  #45
thank you! that is a BIG difference from what i had found. now if i could just remember where i put that torque wrench....
Old Oct 13, 2022 | 05:28 PM
  #46
Don’t forget to put some antiseize on the threads, to help next end link change, you’ll be thankful you did!
kmcrae476
53
Aug 29, 2015 07:40 AM
The bull
7
Jun 30, 2014 01:25 AM
gvander
Jun 11, 2014 04:57 PM
Alexwsilver2010
13
Mar 17, 2014 01:47 AM
Musicguy
May 1, 2012 09:56 AM
