ABS control valve / module
Old Jan 6, 2021 | 07:34 PM
Those GM retailers are just resellers not officially GM dealers.
Old Jan 6, 2021 | 07:36 PM
19301489 is for cars with active brake control. Does your passenger side glovebox door RPO sticker show JL4?
Old Jan 6, 2021 | 09:26 PM
Universal or not the EBCM needs programming.
Old Jan 31, 2021 | 08:03 PM
letterman7's Avatar
Update to the situation. The module quoted above is for the SS, which I bought since I did the four wheel disc conversion. However, that module has to be able to communicate with the electronics module it's plugged in to, and that module also has to be "SS" related. Since I bought an SS modulator and an LT/LS control module, neither one worked since neither one could be programmed to talk to each other. So, control module 20827127 and modulator valve 19301486 were ordered. And everything seems to be copacetic at the moment. Brakes are perfect.. snow is on the ground now, so I'm sure I'll see how the ABS works here in a day or two.
Shisbey01
16
Sep 29, 2019 11:45 PM
D.Brown
Jun 24, 2016 08:43 AM
us11csalyer
17
Jan 23, 2012 07:38 AM
5speed4
Mar 13, 2008 09:12 AM
