ABS problems without code or light
Old Aug 29, 2020 | 11:04 PM
What does "I got the bushings done on all the wheels." mean?
Old Aug 29, 2020 | 11:08 PM
Bonez's Avatar
Originally Posted by Rollie2004
The bushings were just replaced at the end of July, the shocks and struts are a year old. The mechanics did a diagnostic and close inspection and the only thing wrong is it needs an alignment, it needed the alignment before the things started happening. Researching the issues and what it's doing I found that a wheel speed sensor going bad or even just being dirty can make the pedal pulsate at lows speeds when braking and make the grinding noise like it's doing now.
sounds like a bad hub.
Old Aug 30, 2020 | 08:08 AM
Pulsating and grinding , low speed braking, bushings replaced, seems like a bad hub to me.
Old Aug 30, 2020 | 11:39 AM
Rollie2004's Avatar
Any suggestions on how to figure out which hub or should just replace both front ones?
Old Aug 30, 2020 | 12:17 PM
Lonwane's Avatar
Replace both. They are not that expensive.
Just get a good brand.
I prefer Timken.
Old Aug 31, 2020 | 06:37 AM
I just installed PowerStop hubs , I purchased from RockAuto.
job247
May 4, 2018 12:51 PM
alexrckid
Sep 11, 2017 05:26 PM
Tattoo_sinner
Jan 12, 2017 10:05 PM
canroc
Sep 18, 2014 04:29 PM
jbiesent
May 22, 2011 08:08 PM
