Brake upgrade to SS brakes ....
Old Apr 11, 2015 | 08:13 PM
lazaino's Avatar
Originally Posted by 07azhhr
A new question has popped into my head that could help here. What is the general concensus about the difference in stopping power between the non Brembo's and the Brembo's from the SS owners? Especially from those that have converted.
I can't assure you that it will stop faster for one stop, but the pedal pressure to engage the ABS dropped to a point that playing with finding the point of lockup is easy. The pedal pressure wet down considerably and my satisfaction with the brakes went up considerably. As I've said before, if I ever acquire another HHR, SS or not, I would do the upgrade even if it required new wheels and tires.
Ira
Old Apr 11, 2015 | 10:12 PM
07azhhr's Avatar
Ira
Cool, thank you.
Old Apr 13, 2015 | 12:05 PM
LT1GMC's Avatar
A big difference, and much longer life as well. My fronts needed pads every 22k miles, Brembos look like new at 25k
Old Apr 13, 2015 | 04:18 PM
07azhhr's Avatar
Longer life is a plus for sure. Especially right now while I am trying to prolong the remander of my clutches life by not using engine braking so much at this point. While not spirited driving, I drive 95% city with 19 stop lights on my way to and from work I use the brakes a lot.
Do you do a lot of spirited driving and city driving thru those miles?
Old Apr 14, 2015 | 11:57 AM
paperboy72's Avatar
if you are in need of a complete set of calipers from an SS hit me up, i just bought a set of Brembo's I will be swapping out. I have a complete set front and back calipers if you have any interest.....
Old Apr 14, 2015 | 01:25 PM
solman98's Avatar
I was one of the early adopters for this upgrade (non Brembo SS). If your needing rotors and pads, it's an easy and cheap upgrade. You won't be disappointed.
Old Apr 14, 2015 | 02:57 PM
07azhhr's Avatar
Still undecided between Brembo or non Brembo. Either way I prefer to use new parts. But thanks for the offer Paperboy72.
Paperboy72 how many miles have you typically gotten from your front pads?
Solman you were still using the LS/LT pads correct?
Old Apr 14, 2015 | 02:59 PM
I followed Solman98's thread and purchased used SS caliper brackets and calipers from LT1GMC when he upgraded his SS to Brembo's , I am very happy with the upgrade to my LS ! Now flip a coin and order up either set up as you have the room with 20's and get that satisfied feeling and start wondering why didn't I do this along time ago!
You will not regret it!!
Old Apr 14, 2015 | 03:33 PM
07azhhr's Avatar
LT1 up above stated his non Brembo's only lasting 22k miles repeatedly. So I would like to know from you and others what yours have lasted. Especially you and solman if you were still using the LS/LT pads vs the non Brembo SS pads.
Old Apr 14, 2015 | 07:02 PM
Pads are the same, mine have 63,000 klms on them or 40,000 miles and I just changed them they were close to the squealer tabs so I changed them
