Lower control arm rear bushing
Old Mar 10, 2024 | 08:18 AM
Found this on the internet
Old Mar 10, 2024 | 08:23 AM
Old Mar 10, 2024 | 10:35 AM
If you wanted to go through the effort you could drop the the cradle to get to the captured nut and tack weld it. I don't think I would use a nylon nut. Try to get the nut and bolt be close on the Galvanic scale to avoid corrosion. Maybe some ant-seize or dielectric grease would help the next guy.
You would not want a loose fit in the bushing sleeve, that would defeat the purpose. Needs to be a tight clearance fit, almost interference.
Old Mar 10, 2024 | 11:07 AM
Dropping the cradle doesn’t give enough room on the driver’s side to get a MIG wand into weld the cage.
The idea of a large piece of metal with threads and resistance against the length of the piece to hold it from spinning, I don’t know why they wouldn’t have done this in the first place.
Old Mar 10, 2024 | 11:22 AM
I've copied your posts to the how-to tutorial forum, Oldblue, great find!
Old Mar 10, 2024 | 12:10 PM
  #26
PulpFriction's Avatar
I think this is brilliant. Might be more manageable to use much thinner stock and just weld on a nut, tho. Certainly would be for me.
Old Mar 10, 2024 | 04:23 PM
  #27
I meant drop the cradle to the ground, engine, tranny and all.
Old Mar 11, 2024 | 08:31 AM
  #28
fastsuv and I have done that . In Oldblue.
ENASNI TILLER
Maintenance and Upkeep
31
Mar 22, 2024 07:33 AM
FirstGenHHR06
20
Jul 24, 2023 09:36 PM
stidge77
Apr 10, 2019 01:34 PM
alexrckid
11
Feb 26, 2012 07:46 PM
fastsuv
Jan 30, 2012 12:01 PM
