Shock hanging (again)
Old Mar 3, 2012 | 02:55 PM
  #41
And the mystery is solved, glad you got to the root cause. Sometimes "performance parts" are well engineered and designed, and other times they're something cobbled together in a guy's garage...sounds like you go the latter.
Old Mar 3, 2012 | 05:53 PM
  #42
Lee3333's Avatar
How true. Problem is I still am living in the past. Back in the 70's and 80's, I lived in junk yards. I would get parts and adapt them with no problems. Cars were less technical then. I remember getting station wagon springs from an Opel, cutting them down a little and putting them in my Opel GT to make it stiffer and a little lower. These days, cars are made with much stricter tolerances, with no margin for error. Even adding a low amperage accessory to the fuse box in the HHR caused problems-the computer senses the excess current draw. Things are tougher for shade tree mechanics now
But on the positive side the car is running great. I can drive it now without worrying about the missing shock or that the spring could fall out. And it is SOOOOOO much quieter over bumps, I just can't believe the difference!
Old Mar 3, 2012 | 09:00 PM
  #43
Lee- Knew this had to be something with the shocks (as I posted)..
Anyhow, good your friend fixed you up..
I remember 2 years ago, you first posting problems.. Long road.. Glad it has smoothed out for ya finally..
Old Mar 3, 2012 | 09:05 PM
  #44
IgottaWoody's Avatar
Not uncommon to use another vehicles shock to replace one that doesnt fit anymore..though...when going thru the books, one should compare all dimensions before using...My Truck has 2 different shocks on rear because of the way the shock mounts were installed...and everything works fine..I needed 3/4" more compression and got 1 1/2...
Old Mar 3, 2012 | 10:25 PM
  #45
Lee3333's Avatar
In the future, I will have Bobby measure and order the correct shock. Anytime I need to buy things for my HHR or my racecar, I always check with him first to see if it is a good product. And many times, he has told me that while something sounds great, from his experience it does not work as advertised. And a few times when I did not heed his advice, I wound up wishing I had listened to him.
SmootHHR
"How To" Tutorial Library
50
Aug 14, 2018 10:02 AM
lttleric
24
Sep 11, 2013 07:53 PM
wzolla86
Jul 18, 2012 10:33 AM
06Daytona
22
Jul 6, 2010 12:18 PM
Scrivs
Jan 15, 2009 01:39 PM
