Which way to lower?
Old Aug 26, 2007 | 06:31 PM
  #31
06Daytona's Avatar
Originally Posted by LSchicago
I did not take pics of the clamps on the front, but they do clear.
How much did it lower the front and exactly where on the spring did you mount the clamps?
Thanks.
Old Aug 26, 2007 | 08:04 PM
  #32
LSchicago's Avatar
I didn't tighten them on the front, I just put them on to see if they fit. They should lower at least an inch using one per side.
Old Aug 26, 2007 | 08:11 PM
  #33
stick's Avatar
any body try these on lowering springs? goldlines 2nd gen, just wondering if they would lower another inch or so:twothumbs
Old Aug 26, 2007 | 11:04 PM
  #34
LSchicago's Avatar
They will work on lowered springs too, but how low do you want to go?
Old Aug 27, 2007 | 11:23 AM
  #35
jescobe82's Avatar
They will work on any spring as long as you dont have a strut/shock in the spring center. Nice pics of the panel!! Mine was lowered about the same amount just using on clamp per spring. If I used two, it would be lower than the front and I'm not ready to deal with the front end.......just yet.
Old Aug 27, 2007 | 02:21 PM
  #36
LSchicago's Avatar
They will work on the front of the HHR WITH the struts. I may put a set on the front and take another pic. LS
Old Aug 27, 2007 | 05:05 PM
  #37
chingchonger's Avatar
Originally Posted by TruckSHOP.com
Actually, the way he measured it is probably the best way, given he is looking to measure the actual fender well gap. If you were just trying to measure before and after lowering, then the ground-to-fender approach is a good way since there is little error involved measuring from the ground to a given point on the fender. Both sides should be measured in either case.
Flat, level ground is absolutely necessary if you are trying to measure something like fender gap down to a fraction of an inch. Pitch to the ground may cause weight transfer and that will affect the stance. Parking uphill on a driveway vs downhill will cause a difference. Also, if the ground is not flat, say 3 wheels are on the same plane, but one is higher or lower, can affect the measurement at all 4 corners. Even turning the front wheels will raise one side and lower the other due to the caster in the front suspension.
I still think the best way to measure is from the center of the wheel to the fender wheel. As long as you are on a flat and leveled surface, there is virtually no room for error. This is much more accurate then measuring from the ground to the fender since it does not rely on tire inflation.
Old Aug 27, 2007 | 07:35 PM
  #38
LSchicago's Avatar
I put a pair of clamps on the front, It only dropped 1/2" each side, no pic, because it's getting dark here.You can put your finger between the clamps, and the struts. I'll try one more clamp set per spring (F&R) and post the pic here tomorrow. LS
Old Aug 27, 2007 | 07:56 PM
  #39
stick's Avatar
low I want to go as low as I can without causing rubbing or damage to the vehicle.
Old Aug 28, 2007 | 07:40 AM
  #40
06Daytona's Avatar
Thanks for your work on this. I look forward to the results.
