help with check engin light and traction control
Old Oct 30, 2015 | 12:04 AM
Also, as per FMG - we also need "voltage output(static and engine running)" at the alternator and the battery to confirm they are actually up to specs. Like batteries, alternators have been known to be bad right out of the box.
And did anyone check all the grounds as suggested previously?
Old Oct 30, 2015 | 01:42 AM
Beat me to it whopper, but that's what the FSM has in the fault tree to check, voltage output and ground continuity.
Old Nov 2, 2015 | 09:22 AM
lilmoe's Avatar
They did check ground wire and that was fine. They are getting a new alternator today and putting it on to see if the first new one was bad.
Old Nov 2, 2015 | 10:38 AM
lilmoe's Avatar
The shop said with the first new alternator
It was running 14.2-14.4 when running and the battery light is not on. It's running 12 something when light is on. They have not put the second new alternator on yet.
purple people eater
Sep 17, 2016 01:07 PM
Mrb
May 30, 2014 09:57 PM
ImNewHere
May 27, 2014 11:05 PM
WaynesWorld
Apr 1, 2014 06:07 PM
