Kevlar or Ceramic Clutch for Daily Driver
Old Apr 23, 2013 | 09:15 PM
silverstreet's Avatar
Originally Posted by TurboTechRacing
If you are at the level, or want to be, get the stage 3. You will also put less stress on it, as it is capable of holding more. You never want to run a clutch to its limits, it wont last as long.
Stage 3 it is.
Old Apr 23, 2013 | 10:21 PM
JAXFL_SS's Avatar
Originally Posted by silverstreet
What are your HP and Torque numbers that you'd need a stage 3? Just wondering as I'm hoping to do minimum of 340 whp hopefully more and the stage 3 is only a few bucks more. So if it's well drivable on the streets no point in not moving up a stage, or is there?
I don't rightly know what numbers I'm at currently as I have never had it dyno'd. I'm running a solid 24 psi tune at full bore, so I'm guessing 330/360 at the wheels. I can push it to the floor in 5th and it won't slip.
I bought the Stage 3 b/c I would like to swap in a bigger turbo sometime next year. Like you said, only a few dollars more and it will handle it. No need to swap again.
BennieA
29
Jan 5, 2013 08:07 PM
71corvette
Feb 26, 2012 01:55 PM
soccerjunky
Jun 9, 2009 11:25 PM
GDZHHR
Jun 7, 2009 10:44 PM
Jeff®
Jul 19, 2008 04:52 PM
