2007: Can cigarette port 12v be tapped to add 2nd port?
Old Jan 23, 2024 | 09:28 PM
  #31
What do you mean by ignition/ door switch?
Old Jan 23, 2024 | 09:30 PM
  #32
All of the "unused" fuses on the BCM are on the RAP relay; meaning switched and stays alive until the driver door is opened then closed, like the radio.
Old Jan 23, 2024 | 10:35 PM
  #33
Welcome
Pretty sure all HHR's already have a 2nd power outlet at the back of the center console. Will that help ?
I also think the panel HHR's may have a 3rd outlet in the back by the hatch.
You are correct Sir, at least mine does, on R side.
Old Jan 24, 2024 | 07:51 AM
  #34
Yes, the panels had that cargo area power outlet. fuse #7 in the under hood fuse box
Old Jan 24, 2024 | 09:27 AM
  #35
PulpFriction's Avatar
Will this work?
Old Jan 24, 2024 | 10:32 AM
  #36
The problem is that both of the factory outlets are always hot. If you want switched you need to add a wire from the BCM. That is what "ignition/ door switch" means, on the RAP circuit.
Old Jan 24, 2024 | 11:05 AM
  #37
Originally Posted by sands.autolit
Re: The diameter of the in-dash power port vs the rear console power port:
On closer inspection today, the center console power port had 2 pennies lodged inside preventing the use of the port! - Sorry. Never mind! I deleted my "help" question.
And now my tire inflator AND phone can be plugged in now. My apologies for not discovering that earlier.
I hope I didn't damage the 15 amp circuit for the in-dash port because it burned out two 15 amp fuses before I stopped inflating the tire.
Thanks for the quick reply, Oldblue!
I think the 2nd blown fuse turned off the engine at the same time! Is that usually possible? Unless in my haste (it was raining at the time, yesterday) I forgot to turn on the engine that 2nd time? IDK.
second case in this thread resolved. I’m closing this one!
Slyk221
Mar 25, 2021 06:58 AM
donbrew
Sep 16, 2014 12:23 PM
Talia
Sep 30, 2013 10:58 AM
knelson1969
Sep 5, 2012 04:02 AM
weekendwarrior
Jan 20, 2011 08:35 PM
