Auto to manual swap
Old Mar 13, 2022 | 11:15 AM
Timbo's Avatar
Originally Posted by OshawaHHRss
you just have to turn the transmission off in the tune. Changing the gearing doesn’t have anything to do with your tune with a m/t
I have everything I need because I have a complete donor car. I went to start swapping pedals and realized there are no wires for the clutch pedal sensors. I have the manual trans computer and everything but really don't want to swap out the harness under the dash. My question is, either way, I will need to reprogram the computer to hide those sensors. Should I use the manual computer or the auto? And how hard\how much would a reprogram cost? Thanks
Old Mar 13, 2022 | 03:03 PM
PulpFriction's Avatar
It’s been done. Trouble is HHR manuals are rare compared to automatics, although you can fish for Cobalt parts too. Also, the automatic is pretty durable. Pretty sure a guy here did an SS, but that was a highly modded drag machine that destroyed any available automatic. Probably 3-4x your horsepower. Haven’t seen him lately. Oshawa something. If you can handle a lot of idiocy you could lurk the farcebook HHR groups, especially “HHR Performance Mods” or something like that.
But seriously, no way is it worth the trouble. Enjoy watcha got.
Old Mar 12, 2023 | 05:21 AM
OshawaHHRss's Avatar
Theres 2 ways to do it. You can loop the tan wires from the plug at the front of the tranny, set the gear selector in neutral, raise neutral rev limit to redline. That will work with the auto computer and engine harness. Or you can swap to a manual computer and engine harness and run a wire to the clutch position lead on the ecm plug. You’ll need to feed it with 5v reference. I borrowed mine from the sunlight sensor. Everything works as if it came from the factory with a 5 speed
Old Dec 27, 2025 | 06:10 PM
RoadkillPetCollector's Avatar
Smile couldn't pass this one up
...most importantly, throw away your A/T fluid!
jess01999
Apr 14, 2011 10:53 AM
HHR 'Black Death'
Nov 25, 2010 07:40 AM
ufvj217
Mar 15, 2010 12:46 AM
JoeyFeduka
2.0L Performance Tech
13
Nov 5, 2009 07:50 AM
txsman2930
Oct 22, 2006 10:45 AM
