Battery symbol pings on dash occasionally.
Old Jun 15, 2025 | 02:37 PM
Ed ke6bnl's Avatar
The battery symbol comes on the dash with a set of dings. Usually seem to notice it when going up a hill, when engine drops down a gear and ends in about 10 seconds. This is a newer alternator and battery. Did this the first ride with new alternator. Any thought on what to check?
Old Jun 15, 2025 | 04:27 PM
The charging system and the battery. This can be done at most big box auto parts palaces. It can also be the serpentine belt and tensioner is aging and the spring is weak
Old Jun 15, 2025 | 08:39 PM
Everything having to do with the serpentine belt.
Old Jun 15, 2025 | 09:55 PM
Ed ke6bnl's Avatar
New serpentine belt also, leaning towards the tensioner.
Old Jun 16, 2025 | 07:29 AM
It is recommended to replace the belt and tensioner as a pair at the same time.
Old Jun 16, 2025 | 10:22 AM
geg's Avatar
geg
But before that, just check your battery terminals.
The battery should be firmly secured (screwed) to the floor. The terminals should be clean without any white coating and tightly screwed to the battery so that it cannot be turned with bare hands.
Old Jun 17, 2025 | 07:27 AM
PulpFriction's Avatar
The problem most likely is a bad connection at one of several possible points, starting with the battery terminals.
In detail, what led to the alternator and battery replacement?
houseofbugs
Nov 4, 2022 08:20 AM
Squibt
Oct 31, 2021 06:36 AM
Wizard24
Jul 1, 2021 06:58 AM
Tonyautrino
Feb 27, 2018 08:31 AM
jeff schaffer
2.2L Performance Tech
Sep 8, 2013 01:50 AM
