Battery vent tube
Old May 11, 2019 | 03:58 PM
Silverfox's Avatar
I bought mine at NAPA 4 years ago. they were about $27 with sales tax.
Probably a high price but I needed them right away.
I did a temp job on one of the ones I broke.
Clear vinyl tubing the proper size. Cut about 3-4" long.
Use small plastic zip ties on each end.
I questioned your using gorilla glue ??? LOL
Silverfox
Old May 11, 2019 | 08:17 PM
Vinnybagodoughnuts's Avatar
Originally Posted by Oldblue
Try RockAuto for a new one, they’re not very expensive.
They are when you are on your third one.lol Check my link above 3 bucks.
Old May 11, 2019 | 08:27 PM
JB Weld should do it..
Old May 11, 2019 | 09:39 PM
If this one breaks I am just going to strap the battery to the roof.
Old May 12, 2019 | 06:23 AM
That shows it doesn’t fit the HHR.
https://www.rockauto.com/en/catalog/...ent+tube,16762
the correct part is $14.00
Old May 12, 2019 | 08:10 AM
According to some of the people in the reviews it will.I wouldn't be all that shocked if Amazon is wrong but like I said I will update this thread when it arrives.Who knows maybe it will save someone else money.I have purchased the "correct part" three times.
Old May 12, 2019 | 09:24 AM
Odd that an item that expensive is included for free with a new battery.
As long as the tube/grommet fits the hole in the body the Amazon part should work, maybe better.
Old May 12, 2019 | 10:40 AM
I hope so Don. It will be here tomorrow.Not sure if I will need to replace the grommet but I may if it looks like the same one.
My new battery did not include the tube.The funny thing is I have never broken one while installing or removing it.Sometimes if it weren't for bad luck I would have none at all.
Old May 14, 2019 | 01:12 PM
Just ordered another one.
Dorman 924-254 Battery Vent Tube Dorman 924-254 Battery Vent Tube
Not only did it work; it allows for a lot of options.I think I also figured out why mine was breaking.The aftermarket battery I installed has a large ledge under the vent hole.This means it would not allow the barb to fully engage without the 90 pressing against this ledge.It may also explain why so many of you haven't had this problem.The above kit allows you to use the longer end of the 90 in the battery and the shorter side towards the grommet.This allowed the vent to clear the battery without touching it.Both barbs are the same diameter and length.The included tubing is slightly smaller then the oem tube so I did change the grommet with the one provided and it was a perfect fit.Another option if you don't want to change the whole tube or grommet would be to insert the included tubing into the oem tube.It fits perfectly with just the right amount of resistance.You can actually push the included hose through the entire oem tube or just make a splice and add a short amount.
Someone may want to add this kit to the frequently used parts list.By ordering a second one I am sure it will never break again.That's just how my luck runs but for the price you could pick up 4 of these for the cost of the OEM tube.If anyone needs pictures of this I can surely add them.
Old May 14, 2019 | 01:20 PM
They frequently "disappear" on the shelf. Sometimes it is only the 90 and it is hidden somewhere on one of the pieces of plastic.
