Can't Park Straight-Part 2
Old Jun 12, 2008 | 12:15 PM
Cyclic Hardover's Avatar
Well i figured it out and it can made easy with the drivers door. This is where the window meets the slot and goes down in the door. You can use this from the back of the window to the front sort of like a "level."
The car does not sit level as the a$$ end is higher. So if you pull into a parking lot, look at the relation between the lines next to you and the door. if parking lane line is level with your door, your not parked straight. If it's at a bit of an angle , should be fine.
All these other times, I have proven to myself if i feel I'm crooked, then I'm straight along with the opposite. hey , its a slow day.
Old Jun 12, 2008 | 12:25 PM
afs9's Avatar
You know, I just find it easier to open the door and if I look like I'm not sticking out too much on either end, and have ample room to get in/out, I'm good to go!
I'm wondering if it will be easier when I (eventually) level it--the a** does stick up too high!
(yeah, I should be working on a paper, but am here instead! )
whopper
Commonly Used Part Numbers
16
Oct 27, 2024 07:45 PM
BoostedSS
2.0L Performance Tech
16
May 11, 2010 07:39 AM
garagebuilt
98
Apr 27, 2010 11:47 AM
dgmid61
2.4L Performance Tech
11
Feb 4, 2008 05:36 PM
dnvachon
Jun 8, 2006 01:17 PM
