Complete Exhaust systems?
Old Apr 8, 2020 | 06:25 PM
prod's Avatar
I have had the ZZP longtube header with catted downpipe for a few years now. While the quality of the pipe and welds is great, the woven flex pipe they use is crap. Up here where roads are salted mine lasted 2 full years before it started to disintegrate.
It doesnt look easily replaceable either because of the otherwise solid construction, so I would have to buy it as one piece with the cat. Now that we dont require inspection in Ontario, I am considering going catless.
Where you are it probably wont be as bad, but something to be aware of.
Old Apr 8, 2020 | 08:33 PM
Bonez's Avatar
Yeah Im in the Salt Belt, crazy Bi-Polar weather and all. The flex pipe seems to be good, they just said its been welded a few times ( I assume new pipes added as the old gets replaced? ) but a custom shop quoted me $1000 for a complete exhaust Flex pipe back and would probly be half that if the cat is still good, so I need to go have them look at it and see.
Old Apr 8, 2020 | 08:42 PM
Bonez- just know you would be replacing an aluminized stainless exhaust GM uses.
Old Apr 8, 2020 | 08:53 PM
My original was not stainless...
Old Apr 8, 2020 | 09:08 PM
It is not a anti-magnetic aircraft grade stainless, but GM has been using "Aluminized Stainless" exhaust pipes since the 90's at least.
Old Apr 8, 2020 | 09:13 PM
Bonez's Avatar
This thing is nothing but rust held together with welds lol its china steel I bet...
Old Apr 9, 2020 | 11:36 AM
Not in the OEM exhaust, maybe in the replacement pipes.
Old Apr 9, 2020 | 12:11 PM
In my area I know of 2 one man shops with pipe bending equipment. You might try asking some parts delivery guys if they have seen such stuff. Around here there are 15-20 shops in the backyard that get parts from NAPA, this is a pretty small town.
Old Apr 9, 2020 | 01:05 PM
Bonez's Avatar
I should have gotten a picture of the underside while on the lift, Ill be back there soon to get the trans lines replaced, Ill snag one then,,, I don't think anything as far as the exhaust is original , lots of little 2" spacers welded in everywhere so I bet this thing was pieced together as stuff rusted out? maybe the flex pipe is original but as far as everything else, I think its a Frankenstein !
omniglhs
Feb 1, 2018 03:51 PM
PWRWGN
Oct 28, 2013 07:50 AM
Highwang
Mar 14, 2013 08:51 PM
Martial Law
2.0L Performance Tech
13
Feb 21, 2011 12:39 PM
