Does this happen to you
Old Mar 1, 2006 | 07:42 PM
chuktaylor2's Avatar
Question Does this happen to you
Whenever I'm driving and it's dark outside other drivers traveling in the opposite direction seem to flash their high beams at me (which indicates to me my low beams are very bright), which is starting to become more than a little annoying. So now i flash them back (If you think that's bright check this out)!
Old Mar 1, 2006 | 07:43 PM
captain howdy's Avatar
That hasn't happened to me yet.
Old Mar 1, 2006 | 07:49 PM
SIHHR's Avatar
Which mode do you keep your lights on? Daytime running or reg
Old Mar 1, 2006 | 08:00 PM
Daytime.. I never use regular just used to not manually turning them on now.
Old Mar 1, 2006 | 08:34 PM
BIG JIM WOODMAN's Avatar
is your hhr lowered. if so your headlamps need to be adjusted. when you lower the back more that you lower the front the headlamps beam rises. hhrs are stink bugging from factory . m2c
Old Mar 1, 2006 | 09:08 PM
TomsHHR's Avatar
I had to adjust mine down for the same reason. Too high and they are bright.
Old Mar 1, 2006 | 09:23 PM
KNEZRYD's Avatar
My HHR is not lowered but I get the same response often. However, I just looked in the owners manual and it was really easy to adjust the lights down. On either side of the front wheel well you will see a hex key type bolt. If you turn it counter clockwise it will adjust the light down. Hope this helps.
asanti
Feb 9, 2011 07:03 PM
moonsign
Nov 8, 2010 10:54 AM
z28nate
Dec 7, 2008 07:57 PM
xzombiex66
Mar 21, 2008 12:14 AM
SIHHR
Feb 26, 2006 10:02 PM
