ECOTEC 2.4L Questions: What is this?
Old Aug 20, 2006 | 10:50 PM
dan-d's Avatar
Originally Posted by dnbguy86
No offense, you will think your an idiot after i tell you this, but that little tube with the flared end, holds a plastic engine cover, particularily on the cobalts, they just didnt change over the the covers to the HHR's. There is no such thing as a timing probe, nor can it be changed unless its done electronically to change things such as ignition timing, or you can change cam gears, which advances or retards cam timing. Sorry to give you the bad news buddy, but thats the truth.
You may be right on the tube thingy, but yes there is a timing probe that used a tube identical to the one in the picture. Many engines in the 80's and early 90's when cars still had electronic ignitions but were mechanically adjustable (although they were on the front of the engine) did use these probes which were nothing more than a timing light device.
Old Sep 1, 2006 | 03:43 PM
thedonn007's Avatar
Does that mean that we can remove the tube to clean up the enigne bay a little bit more? Once, I get my CGS I will look for some more little things to clean up the engine bay. Also would it be a bad idea to remove the insulation on the hood? maybe it will cool down the engine bay by a degree or two.
Old Sep 1, 2006 | 05:13 PM
SoCalHHR's Avatar
AHNK! (Warning buzzer!) DO NOT remove the hood insulation unless you want to see paint fade first-hand. The temp under the hood will heat and fade your paint in a very short time without the insulation.
Just a warning...
Old Sep 2, 2006 | 11:43 AM
thedonn007's Avatar
I guess that would explain why the paint on the hood of my 84 RX-7 is toasted as well. There was no insulation when I bought it and Rotarys run extremely hot. Thanks for the warning.
RF2
Mods - Engine/Exhaust
Aug 5, 2015 03:02 PM
CactusbobD
2.4L Performance Tech
Dec 8, 2012 01:29 AM
SmootHHR
18
Mar 27, 2010 09:42 AM
EcoBoost
2.0L Performance Tech
14
Oct 9, 2008 05:05 PM
HHRDK
Racing Discussion
May 3, 2008 01:59 PM
