ECOTEC 2.4L Questions: What is this?
Originally Posted by dnbguy86
No offense, you will think your an idiot after i tell you this, but that little tube with the flared end, holds a plastic engine cover, particularily on the cobalts, they just didnt change over the the covers to the HHR's. There is no such thing as a timing probe, nor can it be changed unless its done electronically to change things such as ignition timing, or you can change cam gears, which advances or retards cam timing. Sorry to give you the bad news buddy, but thats the truth.
Does that mean that we can remove the tube to clean up the enigne bay a little bit more? Once, I get my CGS I will look for some more little things to clean up the engine bay. Also would it be a bad idea to remove the insulation on the hood? maybe it will cool down the engine bay by a degree or two.
Just a warning...
