How many of you out there do this?
Old Nov 6, 2017 | 04:42 PM
Silverfox's Avatar
In Washington State we have license plates on the front and back.
I have mastered a way of no noise on either.
Front uses the Factory HHR Black Plastic mounting plate.
Top fits in a groove that holds it, and the bottom fastens with 2 screws but I put a piece of Black Neoprene Closed Cell Foam with adhesive on the back 1/4" thick and 1/2" wide in between the 2 screws so it has a little pressure against the bottom.
The rear, I use a couple of Dealer advertising plastic inserts I've saved in behind the plate so there is no metal touching anything and then either use the factory bottom rubber bumpers or 2" long Neoprene Foam pieces over the bumper hole area to protect the license plate from making contact with the Metal Hatch and close the gap to make the plate fit snug.
I do no use the Plate frames or covers anymore because they cause issues of various types.
Both ends of the HHR are absolutely quiet from Plate Noise.
Silverfox
Old Nov 6, 2017 | 05:33 PM
I use garden hose rings to stop the rattle .
Old Nov 6, 2017 | 06:37 PM
Silverfox's Avatar
If your original bumpers are missing then you better cover the "holes" in the hatch so water does not get in.
Old Nov 6, 2017 | 07:54 PM
Originally Posted by Cat Man HHR
This is interesting.
Went on GM Parts Direct but can't get the right wording to find them.
Might have to go to Ace Hardware as they have all sorts of random bolts/nuts and what not in one isle of the store. Maybe find rubber bumpers that could work.
Edit:
Well I did find this web site
Rubber Bumpers
GM P/N 22628342 but it's moving toward being unavailable. CED has them, ebay, some other places.
Old Nov 7, 2017 | 09:39 AM
PittKrewBowling's Avatar
3/8" Cone washers you can find in the plumbing section of any hardware store. 8 cents, but I buy in bulk LOL
I found the foam weatherstrip was easy to use as well.
Old Nov 7, 2017 | 11:43 AM
  #26
Arf, cone washers!! Are they from France?
Old Nov 14, 2017 | 09:38 AM
  #27
Ok, so another habit I have developed the past month. I always drive with the MPG AVG on display at all times! I guess it helps me keep my foot in check in traffic LOL and I find myself coasting more often.
Old Nov 14, 2017 | 09:52 AM
  #28
Conax's Avatar
I switch back and forth between MPG instant and coolant temp.
I was warned to keep my eye on that coolant temp and I doggedly stare at it for mile after uneventful mile. I guess it's time to let it go and start watching where I'm going again, but that seems so 20th century.
I solved the rattling license plate frame. As I close the hatch I put my fingers under it.
High tech, that's me!
lasater
Feb 1, 2016 01:06 AM
feral
Aug 20, 2013 02:28 PM
mitzkity
South Pacific
Jun 10, 2010 05:25 PM
rockNroad
Mar 25, 2007 11:34 PM
Goose
Feb 6, 2007 09:13 AM
