How to turn off low beam lights
Old Jul 9, 2007 | 10:21 PM
Originally Posted by TomsHHR
It sounds like a wire is crossed, I know you can turn the auto lights off with the switch on the wipers and also in the DIC, but never knew you could turn them off with the dimmer switch...
It sounds like something is not right...
Nothing is "wrong". He did a mod in which he used a 2007 dimmer switch in a 2006 to allow you to be able to turn the dome light on/off with the switch. The 2007's do this, the 2006's didn't.
Apparently this affected the driving lights too. Given a choice I'd rather have control of the dome light that the turn signals as driving lights. A fair trade-off IMO.
Old Jul 9, 2007 | 10:28 PM
Black Rose's Avatar
We definitely need to find out if the dimmer switch mod is causing this or if that particular install had issues.
I want to do the dimmer switch mod, but if it makes my low beams come on as daytime running lights, I'm not going to do it.
Old Jul 9, 2007 | 10:34 PM
oneton's Avatar
GDZHHR; I did that mod of putting the 07 dimmer in my 06 and it works just the same as it did before. front marker lights on when in gear headlights when dark. I don't see anything like he was saying about headlights on all the time.
I like being able to turn the dome light on in the rear, At time when you need to from the drivers seat.
Old Jul 9, 2007 | 11:01 PM
Good to know, thanks for jumping in!
Old Jul 10, 2007 | 07:27 PM
larryv's Avatar
Hello TomsHHR, this is not my car and i quess she needs to read the manual a little better. I had asked her if the outside lights could be controlled with the DIC and she told me that only the inside lights could be. If you have a chance can you please tell me what your light settings are on your 06. As for the dimmer switch, it works fine and is hooked up ie: 1 wire to ground and 1 wire to the gray wire in the fuse box. She must have 1 of the DIC setting in the ON position. Dimmer switch does not turn off the front headlights, it did when I unhooked the dimmer switch wire from the gray wire in the fuse box. All she wants is her amber light only back ON, along with the use of her dimmer. Thanks guys......
Jeff®
Sep 6, 2018 01:27 PM
1BadPig
Mods - Exterior
10
Jul 29, 2009 06:17 PM
ClassicWalt
Oct 30, 2007 06:39 PM
boswald
Jul 17, 2007 09:44 AM
