Installed OEM fogs on 2010 HHR LS-pics and questions.
Old Feb 8, 2011 | 01:07 PM
jerry455's Avatar
ebay has them for sale all the time. I used the one we have in our shop at work.
Old Feb 8, 2011 | 01:12 PM
nacademus's Avatar
Just looked at them...
Almost threw up.
Old Feb 9, 2011 | 05:07 PM
nacademus's Avatar
Well, for those of you who claim the 09/10 LS BCM is not programmable for the factory fog lamps, you're wrong. I paid $39.99 and my dealership programmed my HHR to recognize fogs. Now, when I press the fog lamp switch, the indicator on the dash illuminates.
Now, all I have left to do is to run the trigger lead from the BCM to the fuse box. Once I do that, my lamps should be completed.
I am rather excited, if I must say :)
Old Feb 9, 2011 | 06:17 PM
ufvj217's Avatar
What does the switch look like?
Old Feb 9, 2011 | 07:45 PM
Lucky's Avatar
Glad to here you got it programed. did you ask about remote start?
Old Feb 9, 2011 | 07:57 PM
  #26
skyeglen's Avatar
Almost threw up.
I belive that is called "Sticker Shock"....
Old Feb 9, 2011 | 09:50 PM
  #27
nacademus's Avatar
Like this.
You need a spade bit like this one to make the perfect hole.
I still have to run a wire from the BCM to the engine bay power distribution center... gotta figure that out next.
Old Feb 9, 2011 | 10:07 PM
  #28
nacademus's Avatar
Thanks for all of your help, Lucky. That link will definitely come in handy. :) Now I need to figure out the pinout and where to wire it.
Old Feb 10, 2011 | 09:35 AM
  #29
nacademus's Avatar
Bump for input
Old Feb 10, 2011 | 09:48 AM
  #30
ufvj217's Avatar
so can you turn on the fogs whenever, or do the headlights have to be on for the fogs to work using the factory programmed setup? do they work with high beams as well (i know in my MINI cooper, the factory fogs only work with low beams, they go off with the high beams, and i cant turn them on without the parking or headlights on)
