intake cam shaft senor
Old May 30, 2023 | 03:21 PM
douglas's Avatar
Question intake cam shaft senor
Hi everyone , Just wondering where the cam shaft sensor is located on a 2006 chevy hhr ls 2.2 litre , is it behind the oil fliter? and is there an exhaust senor somewhere. Thank you for your help.
Old May 30, 2023 | 03:54 PM
Here ya go,
Old May 30, 2023 | 03:59 PM
There isn't one on a 2005 2,2L. That is handled by the Ignition Control Module.
Why do you ask? Because you have a code that cites it?
Old May 30, 2023 | 04:09 PM
douglas's Avatar
its a 2006 and i had a engine light come on with a code po340,and not the lights out for 2 days now, it runs fine and idles no problem,sorry the picture is to small to make out, thanks
Old May 30, 2023 | 04:29 PM
greg8453's Avatar
Click through the images. I had to look at it twice.
Old May 30, 2023 | 05:08 PM
The picture does not matter; that is for either a 2006 2.4 or a later model 2.2.
THE 2006 2.2L DOES NOT HAVE CAMSHAFT SENSORS.
P0340 indicates a problem in the ICM.
One more time; the 2006 2.2L is a "wasted spark" ignition. The camshaft positions are calculated by the ICM using spark plug resistance data.
The CEL is set when the ECM does not detect any change in the CMP signal for 107 crank revolutions in 2 consecutive ignition cycles.
Usually caused by a loose wire or failing ICM sometimes by failing or incorrect spark plugs.
Old May 30, 2023 | 07:00 PM
douglas's Avatar
ok,thanks
sciaccio
Oct 21, 2022 05:02 PM
dben719469@aol.com
Jan 5, 2022 08:46 PM
Dasstrum
Maintenance and Upkeep
16
Feb 19, 2017 01:45 PM
crmedlin
Feb 28, 2014 12:15 PM
jojo33
May 20, 2013 12:02 PM
