Need help installing a brake controller to tow a camper with electric brakes
Old May 6, 2011 | 10:16 AM
I just hope the next post we get from orbmas doesn't start with "well we were able to walk away from the accident", you just don't haul more than a vehicle is rated for unless you like asking for trouble.
Old May 6, 2011 | 04:11 PM
Lucky's Avatar
It looks like the wire your looking for is a LT BLUE wire at the brake lamp switch.is powered only when the brake pedal is pushed. should be two of these wires on the same conector pin. this is off of a 2006 wiring diagram.I dont know if its the same on yours. You need to confirm this is the correct wire with a test light. Hope this helps.
07azhhr
47
Dec 7, 2020 05:55 PM
SYNTHKID53
Aug 13, 2013 01:28 PM
Hiperguy
Oct 25, 2010 05:44 PM
joshua_arndt
Jul 13, 2007 06:13 PM
