P0301 - Cylinder 1 misfire 2011 HHR 2.2 Ecotech
Old Apr 30, 2021 | 10:26 AM
  #111
Jessicasdd's Avatar
Even if the code kicked when the flex part of the Cat blew a hole? There was a small hole already and it wasn't triggering the code. It wasn't until it blew the larger hole that the code kicked.
Old Apr 30, 2021 | 11:22 AM
  #112
So, you mean the flex pipe blew out, that would have triggered a different code, but the fact the code tripped after the larger hole, that could be the cause of a gasket fail between the exhaust manifold and the cylinder head.
I try not to reason with the what’s and the why’s, I just look for problem and then, fix it.
Unfortunately I can’t see or hear your engine here in the old interwebs, so I have to depend on you to have a look for me.
Old Apr 30, 2021 | 11:32 AM
  #113
One4 of the criteria the computer uses to determine a miss is the O2 sensor. The O2 sensor shows a rich condition when the #1 cylinder is supposed to be firing. A hole in the exhaust will make the O2 sensor give strange readings depending on the exact circumstances.
Old Apr 30, 2021 | 05:27 PM
  #114
So with that reasoning, Donbrew, you saying the new O2 sensor could be suspect?
what brand of O2 sensor did you buy for the front and the rear sensors on the down pipe?
Old Apr 30, 2021 | 07:55 PM
  #115
No, saying the newly disclosed broken pipe and new cat could be the suspect
Old Apr 30, 2021 | 10:52 PM
  #116
I believe the whole downpipe is new.
Old May 1, 2021 | 09:18 AM
  #117
That reminds me; Has the crankshaft sensor been relearned? That could be the culprit.
Old May 31, 2021 | 08:48 PM
  #118
Jessicasdd's Avatar
Fuel rail had sludge in it pushing against injector 1. Code is clear and car is running like new all over again.
Thank you to everyone who came along on this crazy journey.
Jessica
Old Jun 1, 2021 | 06:02 AM
  #119
Great news! It’s fixed!! So, it was dirt that caused the issue, something simple, not the wrong engine or incorrect injectors, or any other parts! Just good old dirt!
as I always say! Keep it clean and drive it often! Enjoy the ride!
Old Jun 1, 2021 | 07:47 AM
  #120
Gearhead1's Avatar
Excellent. Glad you started at the basics....fuel, fire and compression ....has to run
