Remote Start Discovery
Old Dec 19, 2008 | 04:22 AM
IgottaWoody's Avatar
I believe the "instructions" book tells you to twist it all the way to activate normal controls,otherwise no dash...no radio and steering and shifter are locked..at least my 08 does.
Old Dec 19, 2008 | 07:04 AM
halfpanel08's Avatar
Ha Ha .. My biggest problem is, i'll remote start the car, get out to it, get in and either stick the key in and not turn it or not stick it in, and ill try to put the car in reverse . obviously it wont budge and then i feel dumb for not turnin it actually on. ... AND i also agree with im glad it doesnt grind the flywheel.
Old Dec 19, 2008 | 07:34 AM
twistrman's Avatar
yah once it's started by remote and you get in and put your key in, one turn to where it clicks is your Acc. setting, 2nd click is the ON setting, where you want to be and you will notice dash lights and all that. But on other cars i have had before, if you turned past the ON, just like you were going to start the car (but it's already running) you would grind it.
Old Dec 19, 2008 | 10:28 AM
SargeRN's Avatar
44 degrees/66 degress MUST BE NICE! I'm currently in Northern Arizona it's 0930 and the temp JUST GOT UP TO 32 degrees!! Was 25 when I got up and 30 minutes ago. Remote start OH YES! but like in another thread I'd like it to run a bit longer than the 2 10 minute runs.
Sarge
Old Dec 19, 2008 | 11:38 AM
sargechris's Avatar
Sarge
It is nice... Love Northern AZ--especially Sedona/Oak Creek/Flagstaff...
Old Dec 19, 2008 | 12:34 PM
Smallblock's Avatar
I find my self doing that alot. I'll jump in and then wondery why the **** I can't get it in gear or the window to roll down. Then I'll realize the key is in my pocket.
Old Dec 19, 2008 | 02:35 PM
twistrman's Avatar
My boss has a prius, and you can literally do that. As long as the key is within a certain distance of the car it works. When you get near it it unlocks the doors for you, she hops in and hits the "start" button and off we go. Not a bad trick.
Luister
Sep 22, 2020 08:32 PM
JJ Sparks
Jan 28, 2012 03:49 PM
Mr. Fudd
Jan 27, 2012 04:33 PM
brwalker38
Nov 4, 2011 03:18 PM
HillsdaleHHR
Feb 21, 2009 02:26 PM
