RWD HHR in the works
Old Oct 27, 2013 | 06:07 AM
  #221
lasater's Avatar
Originally Posted by PaperChaseHHR
Agreed! So no radio at all then?
I will be using the after market xm magnetic antenna on the rear of the roof. The one that is about 1 inch square and about a half inch tall. I have one on my panel now and you don't even notice it.
Old Oct 27, 2013 | 06:27 AM
  #222
lasater's Avatar
Details, details
I spent 2 days just working on mounting brackets for the sub frame. The little details seem to take the most time. I'm really going all out on the strength aspect of this build because of seriousness of cutting into a unibody car. All will be for nothing if this car isn't safe to drive. This picture is of one of the brackets that use the old fuel tank mounting holes. I'm trying to make use of as many existing "hard spot" mounts as possible.
Old Oct 27, 2013 | 08:33 AM
  #223
great idea, less holes to drill and nuts to weld in!
Old Nov 1, 2013 | 07:41 PM
  #224
lasater's Avatar
More Fabing
Spent the whole day working on the rear trans mount. Made it out of 3/16" and 1/4" stock. Nuts welded inside so it should be easy to install the actual cross member that has the trans mount on it. Tomorrow I'll tackle the rear axle torque arm. It's gettin' close.....
Old Nov 1, 2013 | 10:19 PM
  #225
Benjiwah's Avatar
This is such a spectacular build! Keep up the great work!!!
Old Nov 1, 2013 | 10:30 PM
  #226
badassbowtie's Avatar
Definitely the most time consuming mod I can think of...Nice work!
Old Nov 2, 2013 | 06:26 AM
  #227
tri94sbc's Avatar
Thanks for spreading your knowledge. This is very helpful. Good luck with the rest of the build.
Old Nov 2, 2013 | 03:40 PM
  #228
lasater's Avatar
Fuel cell mounted
Finished making the straps for mounting the fuel cell out of 1/8 x1 1/2 flat stock steel. Next step is to disassemble the whole thing to finish up some welds I couldn't get to before.
Old Nov 3, 2013 | 05:34 PM
  #229
lasater's Avatar
Sub Frame Finished
I pulled the sub frame out of the mule and finished all the welds. All that is left is some grinding prior to powder coat. I put it on a bathroom scale and it weighed in at 135lbs., pretty hefty. Nobody ever accused me of under building anything. I'm also posting a couple pictures of the trailing arm mounts and how they were modified to clear the rear wheels.
Old Nov 4, 2013 | 09:21 AM
  #230
Nice attention to detail!
