service light
Old 05-22-2017, 08:05 PM
papa_jo's Avatar
service light
Hey ya'll, getting in my car this evening on my way home from work. I started my hhr up and the service air bag light came on, I have no idea. Anyone have this before, and what did you do to get rid of it 2010 hhr panel ls
thanks
papa_jo is offline
Old 05-22-2017, 08:10 PM
Technical Moderator
Have you checked if you are affected by the recall?
https://my.chevrolet.com/recalls
donbrew is offline
Old 05-22-2017, 08:39 PM
papa_jo's Avatar
nope donbrew, no recalls
I am driving car to work tomorrow . I have Wednesday and Thursday off, hopefully I at least find out problem
papa_jo is offline
Old 05-22-2017, 08:46 PM
Technical Moderator
Other frequent problems are thing sitting on the passenger seat.
The TSB on the subject has to do with corroded connectors. The usual offender is on the passenger side kick panel area. https://www.chevyhhr.net/forums/prob...g-light-43456/
You need a special scanner to read airbag codes, but they are there if the light is on, they can at least, give you a direction.
donbrew is offline
Old 05-23-2017, 05:43 AM
aradmahogany's Avatar
I would suggest starting with the kick panel air bag fuse. Pull it out and push it bag into place. That might solve your problem! Gregg once had completely dead gauges, still back-lit, and running fine. All I did was pull out and put back in the fuse for the gauge cluster and I haven't had a problem for the past year! The fuse boxes on the HHR are prone to rockin around.
aradmahogany is offline
Old 05-23-2017, 06:13 PM
papa_jo's Avatar
thanks for the replies.
starting car up this morning to go to work, light did not come back on.
when started this afternoon to come home, light did not come on, so I guess I have a self healing HHR !! it has been raining an awful lot the last few days........... maybe
papa_jo is offline
Old 05-23-2017, 06:15 PM
papa_jo's Avatar
and yes donbrew, my lunchbox sits on the passenger seat,I have the seatbelt fastened.
papa_jo is offline
Old 05-23-2017, 07:44 PM
Technical Moderator
Those connector and wires are right where rain infiltrates.
You may have heard about the problem with Ford pick up trucks. The SDM (airbag module) was mounted on the floor under the driver seat. Keeping in mind that the majority of those trucks were construction vehicles, with the driver getting in and out in rain and mud. The carpet under the driver seat reatains all of that and the connector gets corroded and the SDM shorts out.
donbrew is offline
Old 05-24-2017, 05:29 AM
papa_jo's Avatar
awwwwwwwwwww,,,,,,,, will check that out
papa_jo is offline
Cascious King
05-08-2014 08:50 PM
dlmhhr
12-28-2013 12:43 AM
Lake Runner
12-10-2012 09:33 AM
Marzipan
12-19-2008 10:18 PM
Quick Reply: service light
