Spring is here! wtf is wrong with my sunroof??!!
For some reason, my sunroof doesn't do anything!
Changed the 15a fuse in the interior fuse panel and still nothing.
Anyone else have a problem with this?
Just a thought, check the switch, If you have a volt meter check and see if power is getting to the switch. If it is see if power is getting out. If power is getting out the problem is probablly in the top. I hope this helps.
Ron
Ron
It's pretty unlikely that both of the sunroof switches would fail at the same time. I'm more inclined to think you might have a main power feed problem. Checking the under hood fuse block is a possibility, but it may also be a feed wire for the sunroof circuit that has gone bad. You might end up at a dealership for help on that. At the very least they might be able to give you a wiring diagram of the circuit. Good luck.
