V8 HHR Build
Old Feb 21, 2014 | 11:08 PM
  #131
lasater's Avatar
I think this will work
I took the steering colum apart and cut off the motor area with a band saw. Then I cut the brake pedal mount almost in half to make room for it to go behind the steering colum area. I took the plasma torch and removed the area on the steering colum mount that interfered with the brake pedal mount. I don't have much room but I think it will work. I'll have to rebuild the brake pedal and it's mount but I think there is enough clearance to get by. I don't know what sort of dog-leg I'll need on the brake pedal but it shouldn't be a problem. I will have to re-enforce the brake pedal bracket quite a bit to get the rigidity back in it. I cut it up quite a bit. The red line on the first picture shows where I cut it.
Old Feb 22, 2014 | 10:41 PM
  #132
BlindLizard's Avatar
So, we gonna plan a national g2g in Riverside when lasater gets her done? Bring a bedroll. We can take over a park :)
Old Feb 22, 2014 | 11:40 PM
  #133
Frenchy42's Avatar
I like it. I second the motion.
Old Feb 22, 2014 | 11:48 PM
  #134
Budster's Avatar
x3
Old Feb 23, 2014 | 09:14 AM
  #135
Frenchy42's Avatar
Originally Posted by Budster
x3
Motion approved, motion passed. Now, hurry up and finish that beast so we can all go terrorize Riverside.
Old Feb 23, 2014 | 09:18 AM
  #136
fun trip, but I gotta work!!
Old Feb 23, 2014 | 11:45 AM
  #137
Great excuse to go 2500 miles. I'm aboard.
Boydie
Old Feb 23, 2014 | 11:55 AM
  #138
Frenchy42's Avatar
Depending on when it falls, I'm there. It's 1200 miles for me, if i just shoot down I-5. 1400 if I take the 101.
Old Feb 23, 2014 | 07:28 PM
  #139
lasater's Avatar
Steering / Master Cylinder problem solved
I need to machine a short piece and weld it on to the HHR steering linkage U joint to connect to the Camaro linkage. I also need to weld up the fire wall holes I cut but I'm sure things will work.
Old Mar 2, 2014 | 12:09 PM
  #140
lasater's Avatar
Steering shaft
Spent some time at the lathe yesterday and made the coupling piece to mate Camaro and HHR steering shafts. I welded it in place and it fits good. Since I now have 4 U joints in the shaft instead of 3 I will have to make a support mid way down the shaft to stabilize it. (typical race car/sand rail stuff) I also have to fab and weld in a section of sheet steel with the rubber grommet that the shaft goes thru the firewall. I think I will incorporate it into the brake pedal bracket to strengthen that area.
