V8 HHR Build
Old Mar 2, 2015 | 05:54 AM
  #441
-md- HHR's Avatar
Build looks great man. Do you have any more pictures of the inside floor? Overall stance and everything is spot on.
Old Mar 2, 2015 | 06:25 AM
  #442
lasater's Avatar
Originally Posted by -md- HHR
Do you have any more pictures of the inside floor? .
I have lots of pics of everything. Let me know what you are interested looking at an I'll get you a close up.
Old Mar 2, 2015 | 07:26 AM
  #443
lasater's Avatar
Floor Mods
Before I get off to work this morning I went thru the pics I have of the sheet metal work on the floor/firewall. Here are some. I hope this answers most of your questions.
Old Mar 2, 2015 | 07:43 AM
  #444
-md- HHR's Avatar
More about the inside floor. Wondered how low / high it was, and if you made it 100% flat.
Old Mar 2, 2015 | 08:00 AM
  #445
lasater's Avatar
The actual "floor" was left stock except for the areas under the rear seats that were dimpled down about 1/2". These areas were cut out and will be filled in with a flat piece of sheet metal. This was done to allow the sub frame rail to sit flat against the floor. The "drive shaft hump" area was completely removed and replaced with a taller piece (see Photo #4) as far as the height of this piece, I don't recall, but it was as tall as I could put in this area and not cut out all of the stock body crossmember strength. You will need to check and see how much room your drive shaft and torque will need for clearance (based on ride height) if you are going to do this to your car. Hope this helps.
Old Mar 4, 2015 | 08:36 PM
  #446
lasater's Avatar
Camaro harness
Installing the harness bit by bit. It is thru the fire wall and the ecm is sitting on the floor on the passenger side. Next is to put the sound/heat mat in then mount the computer. The bcm is going in the console. On Monday I should have the Optima battery and mount. It's going on the rear passenger floor. The air compressor for the front struts mounts in the drivers rear floor area.
Old Mar 5, 2015 | 06:06 AM
  #447
Slowly but surely you'll get this beast rolling!
Old Mar 11, 2015 | 09:21 PM
  #448
lasater's Avatar
Engine and Trans together at last
Got them mated together today. Somehow the 3 bolts that hold the torque converter to the flywheel got lost. Luckily my local Chevy dealer had them in stock. These are a semi - special bolts that you really shouldn't substitute just any old bolt. Anyway, it's almost ready to drop in.
The Optima battery is here as is it's hold down bracket.
Old Mar 11, 2015 | 09:33 PM
  #449
Looking good
Funny that you mentioned losing those torque converter bolts. The other day I was looking in my spare parts drawer for a bolt.
I saw 3 torque converter bolts and can't for the life of me remember what they came off of. But, they've been there a looong time. I haven't done any trans. work in about 20 years.
Old Mar 16, 2015 | 09:20 PM
  #450
lasater's Avatar
Little by little
The wiring harness continues. New tach driver wires are being spliced in to send impulses to the 1963 Sun tach. Brake master cylinder is back in. The Line Lock mounts next to it. I need a new starter motor because this one is really sounding strange cranking it over, and it is getting hot. The engine compression ratio is 11 1/2 to 1 so it will require a good starter. We are hoping for the engine to be installed at the end of this week.
