5 speed manual can't shift to 5th
Old May 31, 2022 | 11:22 AM
VenusSS2009's Avatar
Hello Experts. I am new to the forum and not very car savvy. My 2009 SS has a short shift that the previous owner installed a few years back. I can no longer shift into 5th gear. It is like the shifter is hitting a wall. I have no issues with any other gears or reverse...no grinding, no slipping. I have read numerous threads, but have not found this issue as yet. Any ideas of what the problem may be before I take it into a transmission specialist? Thanks!!!
Old May 31, 2022 | 11:51 AM
First thing I would do is look at the linkage on top of the trans while the shifter is being manipulated; look for any obvious blockage or disconnections.
Next, I would remove the trim around the shifter and look for obvious blockages or disconnections.
I don't know why you would take it to a "transmission specialist", more likely it is a simple mechanical problem in the cables.
Old May 31, 2022 | 01:21 PM
X2 check the cable brackets!
https://www.chevyhhr.net/forums/ss-s...s-62162/page3/
Keswick, used to go fishing near there , welcome to the site!
if you need cables the part number
https://www.gmpartsdirect.com/oem-pa...cable-15939191
And from EBay for Donbrew.
https://www.ebay.ca/itm/402009927824...mis&media=COPY
Old May 31, 2022 | 02:58 PM
greg8453's Avatar
You bought it like this? If not, tell us the story of it's failure.
Old May 31, 2022 | 09:42 PM
Quite often, this is fixed by a simple cable adjustment at the shifter.
Old Jun 14, 2022 | 04:39 PM
Thanks DonBrew for the info. Like I had mentioned, I am not that car savvy and to me, the gearbox is all part of the transmission network. I took the car to the mechanic and unfortunately it is not a simple fix. Their tests point to a rod issue at the transmission and since it is beyond their scope, it needs to have a specialist look at it. I am waiting on the transmission shop to call with an appointment. How I wish it was something as easy as you have mentioned. I guess I am not that lucky. Will update thread after they look at it. Thanks again!!!
sklute
May 17, 2015 02:27 PM
coolzzy
Oct 10, 2011 10:24 PM
ballplr
Mar 30, 2010 06:36 PM
Talvanos
2.2L Performance Tech
15
Feb 7, 2010 10:02 AM
Unclesams_SS
Jun 7, 2008 11:14 PM
