Brakes are shot
Old Aug 21, 2009 | 04:29 PM
  #31
ralphb's Avatar
HHR SS Front Brake Pad Replacement
Any further comments ref replacing the stock front pads with Wagner Thermoquiet pads ?
Old Aug 21, 2009 | 04:51 PM
  #32
hyperv6's Avatar
Originally Posted by fasterbbc
just curious do any of you have the Upgrade Brembo Brake package? Does it consist of more than calipers? are the rotors and pads different?
Front caliper, pads and rotors are all it is.
Old Aug 22, 2009 | 12:25 PM
  #33
PTGT 2 HHRSS's Avatar
Most people like to go fast. I also like to stop fast. It's kind of fun trying to see how deep you can go into a turn before breaking - just as much fun as going fast. Probably a good part of the reason I had to replace all four so soon.
Old Aug 22, 2009 | 12:26 PM
  #34
Plan on washing the car today - first time in about a month and the frontwheels are still just as clean as the back.
Old Aug 23, 2009 | 07:22 AM
  #35
MrGTO's Avatar
And have money left for beer:
http://www.tqbestforless.com/howto.html
Old Aug 24, 2009 | 05:41 AM
  #36
ralphb's Avatar
PTGT 2 HHRSS : I left a Visitor Message for you on your profile.
Old Aug 24, 2009 | 01:15 PM
  #37
ATLsilverSS's Avatar
minis have a problem with the ebrake lines being improperly bent which causes the rears to wear rediculously fast. i changed all four at around 40k on mine...went with ebc greenstuffs all around and drilled/slotted rotors all around...after 15k the rotors looked like the day i put them on. and ur right they do stop on a dime but it was freakin scary after i upgraded everything...didn't expect that big of a difference
the compound on the minis was very rough on the rotors and whats on the ss seems to be pretty rough as well. i have 42k on mine but the rotors are very worn. when mine go i'll probably do something similar but probably ebc yellows this time
Originally Posted by silvertoy
Consider yourself lucky with 27K for new brakes, my MINI cooper S only lasted 18K before needing front and then another 5K and the rears went. The fronts went again at 39K. Stopped like a beast, but good stopping power comes with a tradeoff (brake life).
Old Aug 24, 2009 | 04:24 PM
  #38
hyperv6's Avatar
Don't go past the red if you do mostly street driving. Yellow is for track use and they do not recomend it for the street for a reason.
Tougher is not always better. Match the pad to the job.
Old Aug 24, 2009 | 05:14 PM
  #39
JJ's BLACK SS's Avatar
i have 19k on mine all in town driving. i had to replace the pads on the front.
Old Aug 24, 2009 | 07:02 PM
  #40
hyperv you are correct...that's what i meant to post...wasn't thinkin
