Break-in for 2.0 Turbo SS
Old Jul 2, 2008 | 10:51 AM
saltyfishguy's Avatar
Drive it like you stole it!! :twothumbs
Old Jul 2, 2008 | 11:22 AM
ColeTrickle's Avatar
Drive the car like you would everyday. The only thing I would avoid is long periods at the same high rpm range.
I have driven mine hard since day 1
I will change the oil for the first time around 2000 miles
Old Jul 2, 2008 | 11:45 AM
EcoBoost's Avatar
Former Sponsor
I am still a fan of some break in...500 miles at least.
And that initial oil change before you romp it is a must to remove metal particulates sheared from bearing surfaces during break in.
I'll do another change at 1000 miles to also remove metal. Then on to the standard schedule!
Old Jul 2, 2008 | 11:51 AM
SPPD's Avatar
Great advice everyone! Thanks!
I am about 2 hours from delivery and cant wait.
SPPD
Old Jul 2, 2008 | 01:28 PM
bobiroc's Avatar
A lot of talk about oil changes in this thread so I will just ask here. Is it standard oil in the HHR SS. I am just bit over 2000 miles and it still says I have 70% of my oil life left. The dealer and my mechanic said to just wait until it is closer to 0% before I change the oil.
If it is using conventional oil is recommended I change to synthetic?
Old Jul 2, 2008 | 01:38 PM
I think it takes synthetic.
I would change it the first time with 1000-2000 miles (like Eco Boost suggested it ensures you get rid of metal shavings) After that I usually change synthetic every 5000 miles. The cars computer will allow you to go longer as they base it on rpm,speed,etc...
I believe synthetic is good for 7K plus miles
I will prob run mobil 1 10w30
Old Jul 2, 2008 | 03:58 PM
405HP_Z06's Avatar
Originally Posted by SPPD
I will be taking delivery of my new 08 SS tomorrow and was wondering what if any special break-in a turbo car needs. This is my first turbo car and don't know what the difference in break-in is between a NA and turbo engine is. Any advice will be appreciated. I want to do things right with this car, as I expect to have it for many years and many miles.
Thanks,
SPPD
According to page 2-21 of the owners manual, there is no special procedure required for break in.
Old Jul 2, 2008 | 04:04 PM
405HP_Z06's Avatar
According to the owners manual, the 2.0L LNF requires an oil that meets GM spec GM4718M. Just like the Corvette, these come with Mobil 1 5w-30 from the factory. I would recommend the continued use of synthetic oil with OCI's based on quality oil analysis. This is what the owners manual states:
The engine requires a special engine oil meeting GM Standard GM4718M. Oils meeting this standard can be identified with the American Petroleum Institute (API) Certified for Gasoline Engines starburst symbol. However, not all synthetic API oils with the starburst symbol will meet this GM standard. Look for and use only an oil that meets GM Standard GM4718M. For the proper viscosity, see Engine Oil on page 5-15.
Old Jul 2, 2008 | 05:03 PM
bobiroc's Avatar
I guess I could of read the manual but that would have been the easy way . I was asking because I was going to change to synthetic if it was not already
Old Jul 5, 2008 | 01:16 PM
Unclesams_SS's Avatar
I took it easy for the first 1,00 miles changed the oil then I have not been very nice to it since then
blacky
Maintenance and Upkeep
Aug 15, 2017 01:25 AM
rodhotter
Nov 27, 2008 09:47 PM
wookie1973
Aug 24, 2007 01:19 PM
yukonfff98
Dec 17, 2006 02:47 PM
Lefty613
Mar 24, 2006 02:23 PM
